Twin BW S400's #1095722
10/16/11 06:44 PM
10/16/11 06:44 PM
New Brunswick, Canada
TrxR Offline OP
TrxR  Offline OP
Do you think a pair of BW S400's would be too big and laggy for a 500CI Street/Strip motor that would have to run on pump fuel on the street? Im thinking about 9.5-10:1 compression. What do you think? Or would I be better off with one big turbo? Looking for something to put a 87 Long box Dakota into the low 9's high 8's
Re: Twin BW S400's [Re: TrxR] #1095723
10/16/11 07:38 PM
10/16/11 07:38 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
prob be to small, what heads? ive got a set of victors stock stroke 440 and im going to use a pair of 76mm to start with, gonna build a 451 low deck, should go high 5s with under 20lbs of boost.
Re: Twin BW S400's [Re: Randy..] #1095724
10/16/11 07:54 PM
10/16/11 07:54 PM
TrxR Offline OP
TrxR  Offline OP
Thinking either a set of Edelbrocks or B1's
Re: Twin BW S400's [Re: TrxR] #1095725
10/16/11 08:41 PM
10/16/11 08:41 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
the Eddy's will get you where you want to be, 500ci and B1s will support a pair of pro mod 88s, the B1s alone can make more power than a stock block can handle.
Re: Twin BW S400's [Re: Randy..] #1095726
10/18/11 02:44 AM
10/18/11 02:44 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
We have two 68.7mm Garretts in our 477. They work pretty well up to over 6000 rpm although they are slightly on the small side for the rest of the engine. However, the lag is almost non existent. If you can get the engine to wake up with the twin S400's, you should have no problem with your ET goals. Our C-body runs 8.5 off idle with DOT tires. http://www.youtube.com/watch?v=lUV_PuIySjQ
Plynouth VIP '67 TT IC EFI
Re: Twin BW S400's [Re: jyrki] #1095727
10/18/11 02:37 PM
10/18/11 02:37 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
my 500" b-1 motor with a single 118 isnt laggy......at all so Im sure the twins would be better....
Re: Twin BW S400's [Re: joshking440] #1095728
10/18/11 05:12 PM
10/18/11 05:12 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
IMO, I would stick with one single turbo with T6 flange. With a big motor, you can easily spool an 88mm turbo and be good for about 1200-1300 HP.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
