Re: Twin BW S400's
[Re: Randy..]
#1095726
10/18/11 02:44 AM
10/18/11 02:44 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
We have two 68.7mm Garretts in our 477. They work pretty well up to over 6000 rpm although they are slightly on the small side for the rest of the engine. However, the lag is almost non existent. If you can get the engine to wake up with the twin S400's, you should have no problem with your ET goals. Our C-body runs 8.5 off idle with DOT tires. http://www.youtube.com/watch?v=lUV_PuIySjQ
Plynouth VIP '67 TT IC EFI
Re: Twin BW S400's
[Re: joshking440]
#1095728
10/18/11 05:12 PM
10/18/11 05:12 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
IMO, I would stick with one single turbo with T6 flange. With a big motor, you can easily spool an 88mm turbo and be good for about 1200-1300 HP.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
