Street/strip 727- what fluid?
#1095526
10/16/11 02:54 PM
10/16/11 02:54 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
Should be firing up the Charger by next weekend and need fluid for the trans. Years back when I had my last 727, I ran B&M Trick Shift in it. An acquaintance at that time used to work for B&M and told me their fluid was just Type F w/ a couple of additives and blue coloring. ![](/ubbthreads/images/graemlins/shruggy.gif) Should I stick w/ Dexron, Type F, or go with an aftermarket fluid? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Tried the Google search here- seems most times the question came up on the Q&A board and got a variety of answers. ![](/ubbthreads/images/graemlins/tongue.gif) What says the Race board? ![](/ubbthreads/images/graemlins/wink.gif) Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) )
Re: Street/strip 727- what fluid?
[Re: MR_P_BODY]
#1095528
10/16/11 03:02 PM
10/16/11 03:02 PM
Posts: 2,128 sweden
sshemi
sweden
Cheapo type F
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: Chris2581]
#1095533
10/16/11 04:05 PM
10/16/11 04:05 PM
I_bleed_MOPAR
Buford, GA
Looks like the experts agree. ![](/ubbthreads/images/graemlins/biggrin.gif) Thanks. ![](/ubbthreads/images/graemlins/thumbs.gif) Tim
[Re: I_bleed_MOPAR]
#1095534
10/16/11 04:07 PM
10/16/11 04:07 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
A quart of non detergent 30w and the remainder type F.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: BlueDart]
#1095536
10/16/11 10:04 PM
10/16/11 10:04 PM
Posts: 20,678 in a cattle trailer down by th...
Guitar Jones
Well I guess I'm going to be the lone dissenting voice. I use synthetic fluid exclusively in all my stuff. It lasts longer, isn't affected by heat and will increase your stall speed about 300 rpm. Amsoil is probably as good as it gets but there are plenty of others including Mopar ATF+4. I use Hyundai SP III because I get it for free but it's just synthetic Dexron.
Type F is a friction modified fluid Ford had to use because their transmission clutch packs wouldn't hold. It's really not a viable fluid with todays materials, it's 40 year old technology that has past it's usefulness.
[Re: Guitar Jones]
#1095538
10/16/11 11:04 PM
10/16/11 11:04 PM
Posts: 5,992 Anoka County, MN
Leigh
Anoka County, MN
A couple of things. You do realize, that Amzoil synthetic atf mimicks Type F. And, 00232-19012 SP111 is spendy in quart bottles. Around $4.50 per qt. cost (I'm a Hyundai Parts Manager). If you get it free, kudos. I know I wouldn't buy it, with all the other choices.
[Re: Leigh]
#1095540
10/17/11 10:04 AM
10/17/11 10:04 AM
Guitar Jones
Yeah I wouldn't buy it either but hey, the price is right. ![](/ubbthreads/images/graemlins/laugh2.gif)
Amsoil makes several different types of ATF, but I know it lasts a long time. The altered I drove has had Amsoil in it's PG for 5 years and it is still good. Many guys tell me that mineral Dexron lasts about 15 passes in their glides.
[Re: MR_P_BODY]
#1095542
10/17/11 10:25 AM
10/17/11 10:25 AM
Posts: 660 San Diego
formula S
San Diego
So its Perfect for a 50 year old design torqueflite. B&M fluid is type F ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: 71cuda]
#1095544
10/17/11 11:10 AM
10/17/11 11:10 AM
Guitar Jones
i use synthetic fluid atf+4.in both my cars.9sec duster and 11 sec street strip duster.i think it depends on how much you race it.i run 2 classes,14-15 runs in a day.later rounds back to back.i foot brake and it seems my launch rpm stays does not vary as much when the trans is hot with synthetic fluid . i have over $1000 in my transmission $4.00 a quart is not that big of a deal.
Exactly, $1000 for a torque converter, $700 for a valve body, not to mention good clutches, steels and bands and you're going to cheap out on the fluid? Doesn't make sense.
