Street/strip 727- what fluid? #1095526
10/16/11 02:54 PM
10/16/11 02:54 PM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
Should be firing up the Charger by next weekend and need fluid for the trans. Years back when I had my last 727, I ran B&M Trick Shift in it. An acquaintance at that time used to work for B&M and told me their fluid was just Type F w/ a couple of additives and blue coloring. Should I stick w/ Dexron, Type F, or go with an aftermarket fluid? Tried the Google search here- seems most times the question came up on the Q&A board and got a variety of answers. What says the Race board?
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Street/strip 727- what fluid? [Re: I_bleed_MOPAR] #1095527
10/16/11 02:59 PM
10/16/11 02:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cheapo type F
Re: Street/strip 727- what fluid? [Re: MR_P_BODY] #1095528
10/16/11 03:02 PM
10/16/11 03:02 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Cheapo type F
Re: Street/strip 727- what fluid? [Re: MR_P_BODY] #1095529
10/16/11 03:07 PM
10/16/11 03:07 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Re: Street/strip 727- what fluid? [Re: MR_P_BODY] #1095530
10/16/11 03:07 PM
10/16/11 03:07 PM
Get-X Offline
Get-X  Offline
Cheapo type F
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Street/strip 727- what fluid? [Re: Get-X] #1095531
10/16/11 03:16 PM
10/16/11 03:16 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
What they all said!
Re: Street/strip 727- what fluid? [Re: I_bleed_MOPAR] #1095532
10/16/11 03:46 PM
10/16/11 03:46 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Wally Mart Type F here..works great.
Nautilus Racing-
Re: Street/strip 727- what fluid? [Re: Chris2581] #1095533
10/16/11 04:05 PM
10/16/11 04:05 PM
Buford, GA
Buford, GA
Looks like the experts agree.
Thanks.
Tim
'71 Charger 383/727
Re: Street/strip 727- what fluid? [Re: I_bleed_MOPAR] #1095534
10/16/11 04:07 PM
10/16/11 04:07 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
A quart of non detergent 30w and the remainder type F.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Street/strip 727- what fluid? [Re: Evil Spirit] #1095535
10/16/11 07:25 PM
10/16/11 07:25 PM
Walhalla, SC
BlueDart Offline
BlueDart  Offline
Walhalla, SC
Been doing this for years with very good results
Re: Street/strip 727- what fluid? [Re: BlueDart] #1095536
10/16/11 10:04 PM
10/16/11 10:04 PM
Guitar Jones Offline
Well I guess I'm going to be the lone dissenting voice. I use synthetic fluid exclusively in all my stuff. It lasts longer, isn't affected by heat and will increase your stall speed about 300 rpm. Amsoil is probably as good as it gets but there are plenty of others including Mopar ATF+4. I use Hyundai SP III because I get it for free but it's just synthetic Dexron.
Type F is a friction modified fluid Ford had to use because their transmission clutch packs wouldn't hold. It's really not a viable fluid with todays materials, it's 40 year old technology that has past it's usefulness.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Street/strip 727- what fluid? [Re: Guitar Jones] #1095537
10/16/11 11:00 PM
10/16/11 11:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
And I'll continue to use the cheap old stuff since
I still get 1.19 60' out of it... and my trans hasnt
been opened up in 4 years now
Re: Street/strip 727- what fluid? [Re: Guitar Jones] #1095538
10/16/11 11:04 PM
10/16/11 11:04 PM
Anoka County, MN
Leigh Online content
Leigh  Online Content
Anoka County, MN
A couple of things. You do realize, that Amzoil synthetic atf mimicks Type F.
And, 00232-19012 SP111 is spendy in quart bottles. Around $4.50 per qt. cost (I'm a Hyundai Parts Manager). If you get it free, kudos. I know I wouldn't buy it, with all the other choices.
Re: Street/strip 727- what fluid? [Re: I_bleed_MOPAR] #1095539
10/17/11 09:27 AM
10/17/11 09:27 AM
ccarson Offline
ccarson  Offline
When I went to pick up my Transmission, before I walked out the door my Transmission Builder handed me a case of Motorcraft Type F, He just said 'this is what I use"
Re: Street/strip 727- what fluid? [Re: Leigh] #1095540
10/17/11 10:04 AM
10/17/11 10:04 AM
Yeah I wouldn't buy it either but hey, the price is right.
Amsoil makes several different types of ATF, but I know it lasts a long time. The altered I drove has had Amsoil in it's PG for 5 years and it is still good. Many guys tell me that mineral Dexron lasts about 15 passes in their glides.
Re: Street/strip 727- what fluid? [Re: I_bleed_MOPAR] #1095541
10/17/11 10:16 AM
10/17/11 10:16 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Type F at walmart is 1.27 a quart
Re: Street/strip 727- what fluid? [Re: MR_P_BODY] #1095542
10/17/11 10:25 AM
10/17/11 10:25 AM
San Diego
formula S Offline
formula S  Offline
San Diego
So its Perfect for a 50 year old design torqueflite. B&M fluid is type F
Re: Street/strip 727- what fluid? [Re: formula S] #1095543
10/17/11 10:56 AM
10/17/11 10:56 AM
upstate new york
71cuda Offline
71cuda  Offline
upstate new york
i use synthetic fluid atf+4.in both my cars.9sec duster and 11 sec street strip duster.i think it depends on how much you race it.i run 2 classes,14-15 runs in a day.later rounds back to back.i foot brake and it seems my launch rpm stays does not vary as much when the trans is hot with synthetic fluid .
i have over $1000 in my transmission $4.00 a quart is not that big of a deal.
Re: Street/strip 727- what fluid? [Re: 71cuda] #1095544
10/17/11 11:10 AM
10/17/11 11:10 AM
Exactly, $1000 for a torque converter, $700 for a valve body, not to mention good clutches, steels and bands and you're going to cheap out on the fluid? Doesn't make sense.
Re: Street/strip 727- what fluid? [Re: Guitar Jones] #1095545
10/17/11 11:50 AM
10/17/11 11:50 AM
Get-X Offline
Get-X  Offline
For me it's not "cheaping out" as much as it's using what's proven to be a reliable fluid for 727s for 30 years for me. I don't ever remember a trans failure related to using type f in a 727. I do however acknowledge the fact that dino oil viscosity will be less stable with temperature swings than synthetics so the stall speed argument has some merit.
'65 Belvedere
'68 GTX
'57 Dodge pickup
