Transmission driveshaft problems #1095311
10/16/11 03:39 AM
10/16/11 03:39 AM
Canada
Cape Offline OP
Cape  Offline OP
Canada
My problem is that I have the drive shaft disconnected at the rearend but the dam thing won't slide out at the transmission side. It's a 833 tranny and it's never done this before. I can't figure it out. Thanks
Re: Transmission driveshaft problems [Re: Cape] #1095312
10/16/11 03:58 AM
10/16/11 03:58 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Give it a good yank,most 4 speed yokes have a air bleed hole in the cap at the ujoint automatics don't and some times the suction makes it difficult to pull out,or maybe there is a slight twist to the splines.Try and work it back and forth a little or take a block of wood and a big hammer at smack it at the ujoint.
Re: Transmission driveshaft problems [Re: B G Racing] #1095313
10/16/11 05:52 PM
10/16/11 05:52 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
As said, when you get it off, look carefully for twisted splines, Just went through this and replaced the slip yoke.
Re: Transmission driveshaft problems [Re: B G Racing] #1095314
10/16/11 05:56 PM
10/16/11 05:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wack it with a wood block and HAMMER
Re: Transmission driveshaft problems [Re: Cape] #1095315
10/16/11 06:19 PM
10/16/11 06:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Throw cold water on it.
Re: Transmission driveshaft problems [Re: John_Kunkel] #1095316
10/16/11 07:16 PM
10/16/11 07:16 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
spoken from experience.
Re: Transmission driveshaft problems [Re: Lee446] #1095317
10/16/11 09:49 PM
10/16/11 09:49 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
X2 with a friends car recently. Spicer yoke had twisted splines that jammed when moving the DL forward after unbolting from rear end. It now has an OE 7290 yoke. This is a smallblock car too.
