Re: Transmission driveshaft problems
[Re: B G Racing]
#1095314
10/16/11 05:56 PM
10/16/11 05:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Give it a good yank,most 4 speed yokes have a air bleed hole in the cap at the ujoint automatics don't and some times the suction makes it difficult to pull out,or maybe there is a slight twist to the splines.Try and work it back and forth a little or take a block of wood and a big hammer at smack it at the ujoint.
wack it with a wood block and HAMMER
[Re: Lee446]
#1095317
10/16/11 09:49 PM
10/16/11 09:49 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
As said, when you get it off, look carefully for twisted splines, Just went through this and replaced the slip yoke.
X2 with a friends car recently. Spicer yoke had twisted splines that jammed when moving the DL forward after unbolting from rear end. It now has an OE 7290 yoke. This is a smallblock car too.
