street strip front tires.
#1094852
10/15/11 09:09 AM
10/15/11 09:09 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
i asked this question over in Q@A,(dont ask me why)but its for you street strip guys.i finally got my bump steer problem addressed.every front end guy ive talked to said i really need to get rid of my steel belted rdials on the front to get the best steering on my car.what i have is 235/60 R15 on the front and MT ET streets 15x30 x12 on the back.what are some of you sreet strip guys runnin.its a heavy B-body, caltracs.
Re: street strip front tires.
[Re: smokinwoody]
#1094858
10/15/11 12:09 PM
10/15/11 12:09 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
my car doesn't weigh as much as yours ..I use BFG's Comp T/A's in 215/60x15 and Drag T/A's in rear 275/60x15
handles like on rails and great traction on the street....never had good luck w/Drag T/A's on track, but the fronts are great
this will give you an idea on the fronts..
its really hard to see the tires with the headlights in the way.
[Re: smokinwoody]
#1094861
10/15/11 12:22 PM
10/15/11 12:22 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
i looked in the jegs cat and the MT ET streets are all refered to as rear tires,will they work as fronts?
[Re: bonefish]
#1094862
10/15/11 12:27 PM
10/15/11 12:27 PM
Posts: 7,506 Az
Crizila
Az
Hoosier 31" Quick time pro's out back and Firestone Indy 500's (P225/70R15's) on 6" aluminum wheels up front. 4000 car. Handles great @ 115.
Fastest 300
[Re: GTXX]
#1094868
10/15/11 10:43 PM
10/15/11 10:43 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I run 165 80 r15s on my 65 Belvedere with Mickey n50 bias rear.My kid runs 215 75 r15s on the 62 300 with Mickey L60 15s bias rears.Never any problems with either and both get lots of street and strip miles.I had Mickey bias on the fronts of both cars.They were total garbage.Even at the track they were all over the place.Now I can let the wheel go at 120 and it stays straight.Rocky
Chrysler Firepower
[Re: bonefish]
#1094869
10/16/11 05:50 AM
10/16/11 05:50 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I used a 215/75/D/15 which is a bias tire that is very close to the same size as a Moroso 7.10x15.
[Re: Chris2581]
#1094870
10/17/11 12:30 AM
10/17/11 12:30 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
My preference has always been the Moroso bias ply and 29+ inches tall.Out back are 16.5 X 31's.I prefer the bias all the way around.The gets driven upwards to 2000 miles a year and 4 or 5 trips to the track
DRAG TIRE SPECIFICATIONS
SPECS DRAG SPECIAL Part No. 17050 17100 17600 Size 5.50 x 15 7.10 x 15 7.60 x 15 Approx. Weight 10 lbs. 11 lbs. 13 lbs. Diameter 25-1/4 in. 27-3/4 in. 29-1/4 in. Tread Width 3-1/2 in. 4-1/8 in. 4-5/8 in. Recommended Rim Width 3 1/2 in. - 4 in. 3 1/2 in. - 5 in. 3 1/2 in. - 5 in. Operating Pressure 30-35 lbs. 30-35 lbs. 30-35 lbs. Ply 2 2 2 Type Tubeless Tubeless Tubeless Circumference 78 in. 87-3/4 in. 90-3/4 in.
Rim 4.0 5.0 5.0 Tire Width (in) 5.7 7.4 8.0
SPECS DS - 2™ Part No. 17023 17040 17025 17026 17028 Size 23.0 x 5.0 x-15 24.0 x 5.0 x-15 25.0 x 4.5 x-15 26.0 x 4.5 x-15 28.0 x 4.5 x-15 Approx. Weight 11 lbs. 11 lbs. 12 lbs. 12 lbs. 13 lbs. Diameter 23 in. 24 in. 25 in. 26 in. 28 in. Circumference 72-7/16 in. 76-7/16 in. 78-1/4 in. 81 in. 86-3/8 in. Tread Width 5.0 in. 5.0 in. 4.5 in. 4.5 in. 4.5 in. Recommended Rim Width 3 1/2 in. - 6 1/2 in. 3 1/2 in. - 6 1/2 in. 3 1/2 in. - 5 in. 3 1/2 in. - 5 in. 3 1/2 in. - 5 in. Operating Pressure 30 psi 30 psi 30 psi 30 psi 30 psi Rim 5.0 4.0 5.0 5.0 Tire Width (in) 6.8 6.4 7.1 7.7
Note: for each one-half inch change in rim width, thesection width will change .20 inch.
