Re: Six Pack Rocker Arms
[Re: moparsquid]
#1094759
10/15/11 01:02 AM
10/15/11 01:02 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
340 6 pac rockers?
only new ones are Harland Sharp...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1094760
10/15/11 01:08 AM
10/15/11 01:08 AM
Posts: 205 Martinsville, VA
440child
Martinsville, VA
340 6 pac rockers?
Sorry, I forgot to say I want them for a 440.
[Re: 440child]
#1094761
10/15/11 01:13 AM
10/15/11 01:13 AM
70AARcuda
las vegas
never knew that the 440 6 pac used anything but stock rockers from the factory....
Tony
[Re: 70AARcuda]
#1094762
10/15/11 01:41 AM
10/15/11 01:41 AM
440child
Martinsville, VA
I don't know, I just remember that Hughes Engines used to sell a heavy duty version of the stock rockers and they were listed as six pack rockers, IIRC. What I'm really looking for is a rocker arm that'll handle around a .550 lift cam & still fit under a stock valve cover.
[Re: 440child]
#1094765
10/15/11 08:27 AM
10/15/11 08:27 AM
Posts: 7,664 IN
ahy
IN
Sometime in the late 60's the stamped rocker got re-inforced at the tip to make the "6 pack" rocker.
Since then Chrysler and the aftermarket standarized on the heavy duty design. Any new replacement stamped rocker should be the "6 pack" design.
[Re: ahy]
#1094766
10/15/11 12:00 PM
10/15/11 12:00 PM
Posts: 75,059 U.S.S.A.
JohnRR
U.S.S.A.
I bought a set of the MP rockers ,though I didn't compare them to a stock rocker, I don't think they looked any different than the rockers I took out of a 73 440 I disassembled. Maybe someone could weigh a stock run of the mill rocker and one of these to see the difference ?
[Re: JohnRR]
#1094767
10/15/11 02:28 PM
10/15/11 02:28 PM
440child
Martinsville, VA
That would be nice if someone just happenned to have them to compare. Not to change the thread, but I plan to use these w/ a hydraulic roller in the .550ish range. Does anyone see a problem with this? Thanks for all the replies so far.
[Re: ahy]
#1094773
10/15/11 10:16 PM
10/15/11 10:16 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
The spring load required for .55 lift will likely push a pushrod through the stamped rocker. Over about .5 lift, the OE stamped get real risky. You need a better rocker.
you need adjustable rockers or a can with less lift and duration.
