Water Pump casting number cross reference #109415
08/23/08 09:48 PM
08/23/08 09:48 PM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
I have a new water pump with a casting number 2402921. I do know it's exactly the right dimensions as what is on the 70 Hemi engines. Anybody know what all the engines and years this pump came on originally?
Thanks for any help.
Re: Water Pump casting number cross reference [Re: Topcat] #109416
08/24/08 10:12 AM
08/24/08 10:12 AM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
This is a list I found of all the casting numbers. Still needing to know.
http://www.gmb.net/html/catalog/2008/2008_WP_CastingNumbers.pdf
But all it does is refer me to this.
http://www.gmb.net/html/products/waterpumps/2008_WP_PictureBook01.pdf
Re: Water Pump casting number cross reference [Re: Topcat] #109417
08/25/08 02:47 AM
08/25/08 02:47 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
68-71 BB/Hemi water pump. Both A/C & Non-A/C used the same casting number. 2843290 - 6 & 8 blade impellers.
Re: Water Pump casting number cross reference [Re: Snoopy] #109418
02/26/09 04:04 PM
02/26/09 04:04 PM
Omaha
road Offline
road  Offline
Omaha
The information states impellers of 6 and 8 with part number 2843290. I have one with 10. Is it specific to a certain motor?
Re: Water Pump casting number cross reference [Re: road] #109419
02/26/09 04:15 PM
02/26/09 04:15 PM
Snoopy Offline
Snoopy  Offline
With A/C = 6 blades
W/O A/C = 8 blades
Hemi = blades
I haven't seen any stock 10 blades. There are a lot of rebuilds floating around, who knows what was installed on them.
Re: Water Pump casting number cross reference [Re: Snoopy] #109420
02/26/09 04:45 PM
02/26/09 04:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Since the Hemi never came with A/C the '68 and earlier used the 8-vane pump and it was driven at near crankshaft speed; in '68 they changed the pullies to drive the pump and fan faster and at the same time the Hemi got the 6-vane A/C pump.
Here's a pic of the 10-vane iron impeller, some impellers were also plastic.
Re: Water Pump casting number cross reference [Re: John_Kunkel] #109421
02/26/09 04:52 PM
02/26/09 04:52 PM
Snoopy Offline
Snoopy  Offline
John,
Is that a 2843290 casting? If so, are you sure that the impeller is original to that pump housing?
Re: Water Pump casting number cross reference [Re: Snoopy] #109422
02/26/09 07:47 PM
02/26/09 07:47 PM
Omaha
road Offline
road  Offline
Omaha
Thought I would send pics of the part I have.
Bill
Re: Water Pump casting number cross reference [Re: road] #109423
02/26/09 07:48 PM
02/26/09 07:48 PM
Omaha
road Offline
road  Offline
Omaha
Here is another.
Re: Water Pump casting number cross reference [Re: road] #109424
02/26/09 07:56 PM
02/26/09 07:56 PM
Snoopy Offline
Snoopy  Offline
Here is a factory water pump rebuild kit for a 2843290 casting water pump. This one is for an A/C or Hemi car. All the original 2843290 casting pumps I have seen have a stamped steel impeller.
Re: Water Pump casting number cross reference [Re: Snoopy] #109425
02/27/09 04:33 PM
02/27/09 04:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I suspect that the basic 2843290 casting would accept both the 6 and 8-vane impellers.
I don't know the casting number of the 10-vane, I just posted the pic to show that they were used.
