Re: Eddy valve stem seals
[Re: davenc]
#1093535
10/13/11 12:43 AM
10/13/11 12:43 AM
Posts: 2,091 Delray beach, Florida
Performance Only
we change the seals out. i'm sure we have the ones you need since we do a lot of those heads. i'm not fond of the seals edelbrock uses.
machine shop owner and engine builder
[Re: MR_P_BODY]
#1093537
10/13/11 12:46 AM
10/13/11 12:46 AM
Performance Only
all eddy heads use a .530 od seal. the id of the inner spring on a 928 is .795 if memory serves me correct
[Re: davenc]
#1093540
10/13/11 01:01 AM
10/13/11 01:01 AM
Performance Only
you might find some of the original seals have come off the guides. they are not a high quality seal and they're pretty big on the o.d.
[Re: davenc]
#1093541
10/13/11 01:01 AM
10/13/11 01:01 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
If the seal is 0.530, wouldn't there be enough room with the 0.795 spring to not worry about contact, clearance, or displacement of the seal?
the eddie seals are big black things. the ones Dan was talking about will be much thinner and better for your application
damn, treed by an old man
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Performance Only]
#1093542
10/13/11 01:10 AM
10/13/11 01:10 AM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
Had that issues with several of my eddy seals... but I also had sticky valve guides as well until they were all cleaned up/machined... switched to comp cams .530 seals. Perfect fit and no clearance issues with my dual springs for my roller.
[Re: davenc]
#1093544
10/13/11 05:32 AM
10/13/11 05:32 AM
moparpollack
Lil Herman
Lil Herman
85086
Does this apply to both big and small block?
