K1 Technologies #1093322
10/12/11 02:44 PM
10/12/11 02:44 PM
Forest Grove,Oregon
beepbeepdon Offline OP
Forest Grove,Oregon
Any one running K1 rods? Whats the general opinion on quality/reputation of these rods as opposed to Manley,Eagle,etc...
Thanks!!!
Re: K1 Technologies [Re: beepbeepdon] #1093323
10/12/11 03:13 PM
10/12/11 03:13 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Been selling and using them probably before almost everyone here. They have been very good pieces, only had a problem with a short run of rods once where they were oversizing the small end bores, and they made changes to correct it.
They are very good pieces for the money, and cant complain a bit about the rods. They have a modest upcharge for 2000 bolts, unlike several others who charge TOO much for that upgrade. Sizing has been good on the big ends, and they maintain the bore dimensions pretty well after relaxing the caps.
I also use Scat, Manleys, Eagles, and Compstars in many of the bracket builds, and I can say they all have their place. I like using the Compstars a bit more in the small chevies as they provide a little more clearance for strokes.
Really, most of the offshore budget type H beam rods now are not bad. I'd put the Compstars in the lead, with K1 a very close second. Scat makes a nice SB stroker rod as well. I'd say Compstar has the most consistent sizing, and K1, Manley and Scat all in the same ballpark after that.
RIP Monte Smith
Re: K1 Technologies [Re: beepbeepdon] #1093324
10/12/11 03:18 PM
10/12/11 03:18 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Good stuff. I have switched to K1 for most of my rotating assembly parts. Earlier this year I built 3 all out race motors, one at 900 HP and have had no issues. The forgings are from overseas, but that's true for most suppliers now. Machining is done in the US and I always upgrade the rods to ARP S2000 bolts which they do before shipping.
Say hello to Tom Molnar for me.
I went with Crower for a >1000 HP HEMI, only because Crower makes a killer billet rod that I like.
Re: K1 Technologies [Re: beepbeepdon] #1093325
10/12/11 03:51 PM
10/12/11 03:51 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
got em in my motor,i believe corrillo is the mother company for them
Re: K1 Technologies [Re: beepbeepdon] #1093326
10/12/11 06:12 PM
10/12/11 06:12 PM
Forest Grove,Oregon
Forest Grove,Oregon
Thanks everyone for your response.I really appreciate it!!!!
Don
Re: K1 Technologies [Re: beepbeepdon] #1093327
10/12/11 06:58 PM
10/12/11 06:58 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I was fortunate enough to be able to compare them side by side with Eagle,Scat,Cat,and Source rods.They had the best fit and finish with more material where you need it.
They are the best rod for the money
Gus
64 Plymouth Savoy
Dana 60
Re: K1 Technologies [Re: beepbeepdon] #1093328
10/12/11 07:09 PM
10/12/11 07:09 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I just bought a set, and while the idea of "Made in China" makes me cringe, they look to be a very nice piece. I looked them over for any visible surface defects and can't find any. As soon as possible I'll send them to the machine shop for OOR and straightness checks.
Tom Molnar used to design rods for Oliver and Carillo is now the parent company for K1.
Yeah, it's got a smallblock.
Re: K1 Technologies [Re: 340B5] #1093329
10/13/11 07:18 PM
10/13/11 07:18 PM
Muncie
Racebuddy Offline
Racebuddy  Offline
Muncie
Running a set in a small block. 927 pin.
good looking and tough. bought them from a MOPARTS member.
