gasoline smell #1092872
10/11/11 08:17 PM
10/11/11 08:17 PM
Ohio
P
pengwin Offline OP
pengwin  Offline OP
P
Ohio
My '74 Challenger smells like gas even though I cannot find any leaks. I have a 5 gal poly fuel cell in the trunk and run -8 line to the regulator and -6 line to the carb. Would an aluminum fuel cell prevent the gas smell better than poly? Should I run solid line up to the regulator instead of braided? I have an attached garage, and I hate my house smelling like fuel. Any suggestions would be appreciated.
Re: gasoline smell [Re: pengwin] #1092873
10/11/11 08:23 PM
10/11/11 08:23 PM
IN
ahy Offline
ahy  Offline
IN
Its often the AN fittings or tank vent. AN swivel fittings, especially the low cost ones, can leak just a little when not pressurized.
Re: gasoline smell [Re: pengwin] #1092874
10/11/11 08:26 PM
10/11/11 08:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The tank has a vent.... they ALL do, so it could be
the vent vapors your smelling
EDIT
Or it could be the fuel in the carb evaporating....
if you can shut the pump off and run the carb out of
fuel when you park it in there to see if its the carb
