Rear hood pin mounting on a Duster #1092529
10/11/11 07:18 AM
10/11/11 07:18 AM
Hazlet, NJ
440Satellite Offline OP
super gas
super gas
Hazlet, NJ
Hey guys, I'm installing a lift off hood and was wondering how you guys are mounting pins in the back. Anyone have pictures or ideas? I was thinking about using a bracket mounted to the firewall but I'm unsure what to fasten it with seeing as I cant get to the backside for a bolt. Any ideas? This is on a 72 Duster.
Butch
1972 Duster 318 4 speed 1958 392 Hemi engine waiting to be built!!!!!
Re: Rear hood pin mounting on a Duster [Re: 440Satellite] #1092530
10/11/11 08:14 AM
10/11/11 08:14 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Mopar Muscle Oct. 2011 ran an article about this subject. Picture number "4" on the lower right shows how they mounted the pins in a 67 Valiant. Should work for your 72 just fine.
I have mechanical Aptitude.
I can screw up anything.
Re: Rear hood pin mounting on a Duster [Re: bboogieart] #1092531
10/11/11 08:18 AM
10/11/11 08:18 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Here is a better shot. I like the way they used the rubber hose for a spacer.
Re: Rear hood pin mounting on a Duster [Re: bboogieart] #1092532
10/11/11 08:22 PM
10/11/11 08:22 PM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
Thanks Bboogieart, thats a great idea. I'll see how stable that is and maybe stiffen it up with a peice of angle iron underneith bolted to the inner fender and have the pin go though both peices of steel. Cool, thanks alot!!!
Butch
Re: Rear hood pin mounting on a Duster [Re: 440Satellite] #1092533
10/13/11 10:01 AM
10/13/11 10:01 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
My Duster has corner braces welded welded on the firewall and then bolted on the inner fenders. The middle small brace for the middle pin is welded to the firewall.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Rear hood pin mounting on a Duster [Re: MY340] #1092534
10/13/11 10:05 AM
10/13/11 10:05 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
Hmmm... The middle one may be bolted now that I think about it. Anyway it's an ugly engine compartment so the hood stays on at car cruises.
Re: Rear hood pin mounting on a Duster [Re: MY340] #1092535
10/13/11 06:09 PM
10/13/11 06:09 PM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
Thanks My340, but thats not really an option seeing as I already painted the engine bay. I think I figured out a good bracket, just gotta test it to see how it works out.
Butch
