Re: T-56 or a 5 speed?
[Re: Fuller]
#1092468
10/11/11 01:52 AM
10/11/11 01:52 AM
Posts: 1,037 Texas, Dallas
G_T
Texas, Dallas
I think the 5 speed will be a significantly easier swap. The T-56 is going to require you to cut and make a custom trans cross member. It is significantly larger transmission. All that said - I'd go with a T-56... but i'm biased
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com
2012 Charger SRT8
[Re: Fuller]
#1092470
10/11/11 02:12 AM
10/11/11 02:12 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I went with a T56 in my car too (non-Mopar though ) If you have to remake stuff anyways, I don't see why not have the advantage of the extra gear And I just set the engine and trans angle the same it was as the donor car basically...
[Re: DaytonaTurbo]
#1092473
10/11/11 09:34 AM
10/11/11 09:34 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
with EFI, I say go for it. but with a carb, I'd say try to keep your cruise RPM above 2000 rpm, or run a "stock" cam with no lope, that is all done power wise, by 5000.
my big block was running a cam that was 1800-6000 rpm power band. I had a TKO with the .64 OD and 3.23 gears with 28" tires.
5th gear was useless unless I was going 70mph or faster, at 65 my RPMs were down at 1700-1800, and the engine was lugging and surging. I tolerated it for a year or so because I knew the whole time that I was planning on 4.56 gears in the rear. and once I did, everything was great! tons of low end, and yet I could still cruise the highway at 2400 rpm, smooth as glass at 70mph.
the TKO will be smaller, and with the .64 OD you don't really need 6 gears. in a 1/4 mile run, you probably will NOT be shifting beyond 4th gear. I feel like you really only need 4 gears for pulling, then a 5th gear OD for cruising.
with that TKO I was running, the 4.56s, 28" tires, the top of 4th gear for me was up around 110-115 mph. I don't need more gears beyond that!
**Photobucket sucks**
[Re: 70Cuda383]
#1092474
10/11/11 09:49 AM
10/11/11 09:49 AM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I went with the T-56 for my 56 Dodge 408 Stroker. I will run it with the EZ-EFI setup. I did a lot of research and unless you can rebuild and upgrade a GM T-56 the brand new in the box Magnum T-56 for about $2800 or so is the way to go. (a GM core will be 800-1200, and you are looking at nnother 800+ for a good rebuild and upgrade). Yes they are BIG but the effort will be worth it. I also have a fairly comprehensive parts list with prices for what it will take to install one to a small block. I learned that I could buy a complete kit for only a few hundred more than I could cobble it together myself.
[Re: Fuller]
#1092485
10/13/11 08:40 AM
10/13/11 08:40 AM
finadk
East Brunswick, NJ
The driveshaft will have to be custom made. Mine came as part of the kit that included the bell, clutch, flywheel, hyd bearing, bolts, etc.
I believe the yoke is a std GM size.
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: finadk]
#1092486
10/13/11 08:44 AM
10/13/11 08:44 AM
finadk
East Brunswick, NJ
As far as the floor, you can make a LOT of room with an acetylene torch and an 8 lb hammer. I cleared about 2" at the bellhousing just by heating and stretching the metal.
Scott
1976 Corvette
