Won't Hold Idle #1092255
10/10/11 05:07 PM
10/10/11 05:07 PM
Los Angeles, CA
Mobarge Offline OP
Mobarge  Offline OP
Los Angeles, CA
General question on vacuum...
Newly-installed six pack won't hold idle below 1,300 RPM in neutral. I'm thinking may be vacuum leak, but increasing RPMs usually signal a vacuum leak, correct? Did not have chance to spray carb cleaner, etc. around manifold surface and carb gaskets.
Butterflies are fully closed in outer carbs, linkage is set, 2 turns out on idle screws on center, 1 turn out on idle set screw (from "square transfer slot setting" in the "unofficial six pack tuning guide on Moparts).
Thoughts?
'71 SSP - SOLD!
Re: Won't Hold Idle [Re: Mobarge] #1092256
10/10/11 06:41 PM
10/10/11 06:41 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
"1 turn out on idle set screw " if this means the mixture screws on the base of the outboards then that is too much. between an 1/8 and a 1/4 is a good starting point. do your check for a vacuum leak all along the bases and your intake runners.
Re: Won't Hold Idle [Re: mikemee1331] #1092257
10/10/11 06:42 PM
10/10/11 06:42 PM
Sure sounds like classic vac leak
