General question on vacuum...
Newly-installed six pack won't hold idle below 1,300 RPM in neutral. I'm thinking may be vacuum leak, but increasing RPMs usually signal a vacuum leak, correct? Did not have chance to spray carb cleaner, etc. around manifold surface and carb gaskets.
Butterflies are fully closed in outer carbs, linkage is set, 2 turns out on idle screws on center, 1 turn out on idle set screw (from "square transfer slot setting" in the "unofficial six pack tuning guide on Moparts).
Thoughts?
