Page 3 of 4 1 2 3 4
Re: Edelbrock rpm head questions..................... [Re: Thumperdart] #1092077
10/11/11 09:08 PM
10/11/11 09:08 PM
SoCal
Brian Hafliger Offline
SoCal
Lower the floor at the pushrod pinch and work it into the short turn...but be carefull or you'll be in H2O!
I'll bet there is at least 20HP in your heads if not more from better porting. Another 10HP with a 2.18 valve.
Brian Hafliger
Re: Edelbrock rpm head questions..................... [Re: Brian Hafliger] #1092078
10/11/11 09:13 PM
10/11/11 09:13 PM
State of confusion
Thumperdart Offline OP
State of confusion
Thankxxx Brian.........any photos? You would of got my heads but I`m gonna do everything to win this bet w/just my dumb a$$ only doin the work.
Re: Edelbrock rpm head questions..................... [Re: Thumperdart] #1092079
10/11/11 09:55 PM
10/11/11 09:55 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Sorry Dom, I can't find any of my build sheets.
Re: Edelbrock rpm head questions..................... [Re: WILD BILL] #1092080
10/11/11 10:13 PM
10/11/11 10:13 PM
State of confusion
State of confusion
No problem........maybe Scott can shoot those #`s to ya! I`m in no hurry and still waiting on my block so I`m leaving no rock unturned on this thing and will milk every bit of power I can find.
Re: Edelbrock rpm head questions..................... [Re: Thumperdart] #1092081
10/11/11 11:36 PM
10/11/11 11:36 PM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
I personally have NEVER had good luck with a 4 hole spacer.
I have about 1.5 inches of open spacer on mine.( tarantula) you have enough carb there. so IMO the best bet would be 1.6 rockers. you would most likely gain even if you used 1.6 only on the intake. and tightened up the exhaust lash a bit.
try some lash changes at the track.
Good luck to you .
cant suggest anything else that doesnt involve a lot of money (porting and bigger valves)
Re: Edelbrock rpm head questions..................... [Re: bumps440] #1092082
10/11/11 11:40 PM
10/11/11 11:40 PM
State of confusion
State of confusion
Thankxxx............the four hole is only a 1/2" and more less there to keep the carb`s guts from falling in the motor but I must say my afr`s sure cleaned up w/it.
Re: Edelbrock rpm head questions..................... [Re: bumps440] #1092083
10/11/11 11:58 PM
10/11/11 11:58 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Going with a bigger (Ferrea)intake valve and sizing the throat at 88-90 percent would defiantly increase performance. 8 intake valves would cost about 150.00 on ebay or from one of our members. Do not get greedy on the throat sizing as it will kill the flow.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Edelbrock rpm head questions..................... [Re: pittsburghracer] #1092084
10/12/11 01:03 AM
10/12/11 01:03 AM
State of confusion
State of confusion
Thankxxx.............I may go to bigger intakes but we`ll soon see.
Re: Edelbrock rpm head questions..................... [Re: Thumperdart] #1092085
10/12/11 04:57 AM
10/12/11 04:57 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
dont know if this helps Dom---
my buddy has been 9.2x or so with RPMs .
this was a couple years ago but off the top of me head..
512"
620 lift roller
ported Rpm heads
72 Cuda --weight = 2800 or so ??
on race gas / dominator
I say try to shave some weight off the car and good luck
Re: Edelbrock rpm head questions..................... [Re: 493_DART] #1092086
10/12/11 11:41 AM
10/12/11 11:41 AM
State of confusion
State of confusion
Man that`s haulin............makes me want to throw in the towel. Not...........after looking at my notes, my car`s right at 3200 w/me and about 10 gallons of gas so 2800lbs would put me REAL close to the mid 9`s depending on what the fuel system, charging problems and the freshen gives me...........we`ll see.
Re: Edelbrock rpm head questions..................... [Re: Thumperdart] #1092087
10/12/11 11:42 PM
10/12/11 11:42 PM
State of confusion
State of confusion
So, does anyone have a part number for some 2.18 or 2.19 intake valves that are the lengths of the e-head valves? George found some but only in 3/8`s that are the same length. Thankxxx........
Re: Edelbrock rpm head questions..................... [Re: Thumperdart] #1092088
10/13/11 12:25 AM
10/13/11 12:25 AM
PA.
"Little"John
"Little"John
PA.
Just did a quick check and I am not sure this would work but check these out. http://www.hughesengines.com/Index/produ...mp;partid=10246
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Edelbrock rpm head questions..................... [Re: pittsburghracer] #1092089
10/13/11 12:31 AM
10/13/11 12:31 AM
State of confusion
State of confusion
Thankxxxx John...........
Re: Edelbrock rpm head questions..................... [Re: Thumperdart] #1092090
10/13/11 12:35 AM
10/13/11 12:35 AM
PA.
"Little"John
"Little"John
PA.
Your welcome.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Edelbrock rpm head questions..................... [Re: pittsburghracer] #1092091
10/13/11 10:58 AM
10/13/11 10:58 AM
tboomer Offline
tboomer  Offline
Pretty good thread,Thumpman! I will be watching this as I may also have to use what I already have!!
Re: Edelbrock rpm head questions..................... [Re: Thumperdart] #1092092
10/13/11 12:45 PM
10/13/11 12:45 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Have you tried locating any pics of MCH's CNC-ported Edelbrocks or Stealth heads to get a feel for what Jeff does? Just a thought...
Re: Edelbrock rpm head questions..................... [Re: pittsburghracer] #1092093
10/13/11 12:55 PM
10/13/11 12:55 PM
BradH Offline
BradH  Offline
That'll work, but it's not as nice a valve as the original stuff that Edelbrock uses.
Re: Edelbrock rpm head questions..................... [Re: BradH] #1092094
10/13/11 01:18 PM
10/13/11 01:18 PM
State of confusion
State of confusion
No I havn`t but I`ll look em up. I`m going to a 2.19 intake valve and the necessary bowl work to take advantage of it so, we`ll soon see.
Re: Edelbrock rpm head questions..................... [Re: Thumperdart] #1092095
10/13/11 01:46 PM
10/13/11 01:46 PM
north west, IN
larry890 Offline
larry890  Offline
north west, IN
my 400-451 w/rpms have been 9.76@135.6 in 3640lbs b-body. i just mch cnc port, then opened the ports to mw and added a indy intake.
Re: Edelbrock rpm head questions..................... [Re: Thumperdart] #1092096
10/13/11 01:54 PM
10/13/11 01:54 PM
BradH Offline
BradH  Offline
FWIW, going to a bigger valve w/o the rest of the port being able to support it won't show much gains. I did the 2.19" upgrade on a set of nicely ported OEM iron castings flowing 270+ and it only picked up maybe 3-4 cfm in the mid lifts w/o any peak gains to speak of.
Page 3 of 4 1 2 3 4
