727 won't shift Update... #1091757
10/09/11 11:14 PM
10/09/11 11:14 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
This all started when it wouldn't stay in first gear off the line. It would go to second without shifting it. Thinking it's a valve body issue I changed it to a manual valve body. Today I get to the track and I can't get it to start off in first gear. I rechecked the linkage and was ok. Every once and a while it will start off in first going though the pits and I shift it to second but then can't get it to go back into first again. Is this a valve body issue or something else? The manual valve body worked in another car before I got it.
Re: 727 won't shift [Re: Todd] #1091758
10/09/11 11:22 PM
10/09/11 11:22 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Does it only happen with first gear?
Could be the sprag going out.
First thing I would do is drop the VB and do an air check to see if everything is applying as it should.
Otherwise, it could be time to open it up and
Re: 727 won't shift [Re: WILD BILL] #1091759
10/09/11 11:52 PM
10/09/11 11:52 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
It has a bolt in sprag that was installed when it was rebuilt less than 20 passes ago. I've never had one of these apart before other than the valve body.
Re: 727 won't shift [Re: Todd] #1091760
10/10/11 12:36 AM
10/10/11 12:36 AM
Guitar Jones Offline
Well first gear is nothing more than the rear clutches and over running clutch w/o a low band apply valve body. If the rear clutch was bad you wouldn't have 2nd or 3rd either, the car wouldn't move so this does sound like an over running clutch problem. Take it out and apart before it does more damage.
Re: 727 won't shift [Re: Guitar Jones] #1091761
10/10/11 12:43 AM
10/10/11 12:43 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
If you like drag racing, support your local track.
Re: 727 won't shift [Re: CHAPPER] #1091762
10/10/11 12:51 AM
10/10/11 12:51 AM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
Hay C-guy .. how is that POPcorn ?
I will BET it is the sprag toooo ...EZ thing to check ... there should be a TON of trash in the bottom of the pan ...
Re: 727 won't shift [Re: dOOc] #1091763
10/10/11 08:41 AM
10/10/11 08:41 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
A bolt in sprag does nothing to overcome the shortcomings of the design.
Re: 727 won't shift [Re: WILD BILL] #1091764
10/10/11 09:19 AM
10/10/11 09:19 AM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Well that just plane sux!!! Never had to tear one down that far so I guess i'm about to learn how its done unless I can get my tranny guy to come over and do it for me. When I had the pan off for the valve body change didn't notice any kind of "trash" in the pan. What will the "trash" look like?
Re: 727 won't shift [Re: Todd] #1091765
10/10/11 02:51 PM
10/10/11 02:51 PM
Check the linkage and shifter adjustment, make sure the cable end will drop into the shifter arm hole in 1st, 2nd, and 3rd gear without forcing it. If it doesn't adjust the cable hieght and angle and so on until it does Did you try centering the valve body on the ten bolts before torqueing it down Little things can, and do, make the monsters arrive I went thruogh recently when I added a blanket on my trans, I ended up having to readjust several things to get it adjusted properly Do the simple stuff first
Re: 727 won't shift [Re: Cab_Burge] #1091766
10/10/11 03:08 PM
10/10/11 03:08 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
When I changed the valve body I ran all the bolts in by hand then tightend. I checked the linkage on the trans and at the shifter in every position and all lines up. The thing seemed to start doing this before I changed to the manual valve body. Thats why I cahnged it thinking that was the problem. Is it possible that the sprag is not holding all the way? And how is it that when the shifter is in first it takes off in second. Isnt there something else like a band thats needs to be applied to make second work that isnt applied in first?
Re: 727 won't shift [Re: Todd] #1091767
10/10/11 03:14 PM
10/10/11 03:14 PM
Yes, the front band is applied for 2nd. The determining factor though was that you said it did this with 2 different VB's. Hard to believe they would both have the same problem. But I guess anything is possible. Other possibilties would be a worn out bushing that has now worn the ring sealing surface and is allowing fluid pressure to go somewhere it wasn't intended. Either way it needs to come apart and very close inspection of all bushings and sealing surfaces completed before condemning any thing.
Re: 727 won't shift [Re: Guitar Jones] #1091768
10/10/11 03:31 PM
10/10/11 03:31 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Is it possible that the rear clutch is slipping enough to make it seem like 2nd gear?
Re: 727 won't shift [Re: Todd] #1091769
10/10/11 04:29 PM
10/10/11 04:29 PM
Well if it was there would be clutch material in the pan and second and third would be slipping too.
Re: 727 won't shift [Re: Todd] #1091770
10/10/11 04:38 PM
10/10/11 04:38 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
i'd check line pressure first. dose ur fluid smell like burnt clutch?? as suggested, i'd do a air pressure test to see if ur clutches & bands are applying. if fliud smells like burnt clutch, it's got to come out. stay safe, seeya.
Re: 727 won't shift [Re: Todd] #1091771
10/10/11 04:39 PM
10/10/11 04:39 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
The rear drum itself could be containing the failed sprag material...
Re: 727 won't shift [Re: dOOc] #1091772
10/10/11 05:31 PM
10/10/11 05:31 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Just got ahold of my trans guy and where're going to drop the valve body and do a air test on it and go from there.
Re: 727 won't shift [Re: Todd] #1091773
10/11/11 01:17 PM
10/11/11 01:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No , the rear clutch is applied in ALL forward gears , if the rear clutch slips you have NEUTRAL.
I can't explain why it appears to be starting in second as the the front band has to be applied for it to be in second.
Did you last VB or this current one have low band apply ? If not then the sprag is toast .
What bolt in sprag did you have installed , the generic case repair kind or the A+A or Coan types ? if the generic type it does nothing to stop the sprag rollers from failing , all it dies it keep the race from spinning in the case.
Re: 727 won't shift [Re: JohnRR] #1091774
10/16/11 08:38 PM
10/16/11 08:38 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Well I got the pan off and found no trash in the pan. Dropped the valve body and did the air test on it and everything operates as should. My trans guy said it all looks really good and suspects the valve body. I took apart the valve body after my trans guy left (he couldn't stay had a honey do list to take care of) and this manual valve body looks like it was converted over from a standard one. The insides have drill marks in spots and some holes in the plate blocked. BTW the sprag is a TCI. He has a turbo action cheeta valve body he is gonna let me try.
Any idea what to look for in that valve body?
