Page 1 of 7 1 2 3 4 5 6 7
SS/DA cuda progress #1091457
10/09/11 09:45 PM
10/09/11 09:45 PM
Kingsville, Md
grncpe Offline OP
grncpe  Offline OP
Kingsville, Md
Hey I posted before about the wheels & it looks like the keystones won by a landslide! Great thats what I like also.Now I just need to find some.I allready posted in the wanted section.15x4 & 15x8x 3 1/2 -4 in backspace is what I need.In the meantime I am putting billit specialties wheels on it.I have some video of the wedge thats going in it also for the begining of the race season.Mild 493 out of my demon.
493ci.
10.7 to 1 comp
Box stock perf. rpms
racer brown stx-21
.560 lift 272@.50
1.6 intake rocker.
victor intake
950 proform carb.
dyno worked out 591hp.@5500rpm.
603.8 tq. @4400 rpm.
so I am happy with that to straighten the car out with before the
other motor goes in.anyway got the link. enjoy!
http://www.youtube.com/watch?v=aPPc6GHZ5-E
Re: SS/DA cuda progress [Re: grncpe] #1091458
10/09/11 10:29 PM
10/09/11 10:29 PM
Locomotion Offline
Locomotion  Offline
Glad you are making progress and the engine sounds great! But I'd like to offer my on your wheel width.
If you want to have as much traction and consistency as possible, I'd suggest getting a wheel that is as wide as possible. Considering the narrow size you are looking at, I'm guessing you don't plan on tubbing it. But I'm pretty sure an E-body wheelwell will accomodate at least a 10" rim with whatever width tire you plan on fitting into it. The widest tire you can fit will work best with a wheel that is at least the same width or even 1"-2" wider! This will provide a flatter footprint while allowing you to run more air pressure for a more stable tire. Wrinkled/wadded-up sidewalls may look impressive, but that "wrinkle" can transfer to the tread surface of the tire and reduce traction. Plus, the higher pressure will help the sidewalls, thus the slicks, last/work longer.
Stock class cars tend to run 9" slicks on 10" rims!
Re: SS/DA cuda progress [Re: Locomotion] #1091459
10/09/11 10:43 PM
10/09/11 10:43 PM
Kingsville, Md
grncpe Offline OP
grncpe  Offline OP
Kingsville, Md
I get what you are saying.I have been in wheel hell for a few weeks.I put 9x30 slicks on it & in my opinion I dont like it.It looks like a stocker.they were on 10 in. rims.I would rather have a 10.5x28 on the car.Ideal would be 10.5x29.5 but it will not fit.I only have 12 in. from the leafspring to the wheel well lip so I am very limited to tire size...I am still on the fence. The keystones will most likely be for show as I would be afraid of breaking them.
Re: SS/DA cuda progress [Re: grncpe] #1091460
10/09/11 11:27 PM
10/09/11 11:27 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What are your plans for the Demon ? Or do you plan to put the 493 back in it ? Ron
Re: SS/DA cuda progress [Re: 383man] #1091461
10/09/11 11:46 PM
10/09/11 11:46 PM
Kingsville, Md
grncpe Offline OP
grncpe  Offline OP
Kingsville, Md
Hey Ron. 1st off congrats on yur motor!and new best!
I just sold the demon a few weeks ago to Jay luckert.
his green duster got wrecked so I sold it to him.
This is my dads old 70 cuda that I have had forever.
last time I drove it was 21 years ago so I figured I would do
something with it.Just finishing up a chrome moly cage in it.I will
post some pics of it if you guys want to see how its going.
I am sending the body to mark dumer to paint it pearl white
in a few weeks.When i get it back I will do all the retro stuff to it. IE: Flake,Candy,& Pearl.I am going for the 70's retro look.
I started building a hemi for it.I have a new mega block 4.50 bore
Alum. heads,& a 4.625 Bryant crank for it so it will be 588 cubes.
small cam with a Rat Roaster.Just enough to get it to go 10.o's for the heads up class & nss stuff. I just want to go out & have some fun.
Re: SS/DA cuda progress [Re: 383man] #1091462
10/10/11 12:29 AM
10/10/11 12:29 AM
Kingsville, Md
grncpe Offline OP
grncpe  Offline OP
Kingsville, Md
Early pic...Want More?
Re: SS/DA cuda progress [Re: grncpe] #1091463
10/10/11 06:35 AM
10/10/11 06:35 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
Yea, just another 50 or so would be great
I'm doing a similar thing & even started a thread on here about my SS/DA build before I sort of swerved off into a (street legal) Pro Stock, Keystones, 488ci Hemi, dual plug, magnesium tunnel ram, solid roller cam etc in my '70 Barracuda so I would love to keep up with your progress & pics
Re: SS/DA cuda progress [Re: grncpe] #1091464
10/10/11 01:02 PM
10/10/11 01:02 PM
Locomotion Offline
Locomotion  Offline
Would it be too far out of your plans to install a 3/4" offset kit for the leaf springs? Aside from relocating the spring pads, it's a bolt-in with no cutting and would still look stock.
Cal-Tracs could help if it doesn't take away too much from the stock look, considering the limited tire size.
Re: SS/DA cuda progress [Re: grncpe] #1091465
10/10/11 01:28 PM
10/10/11 01:28 PM
Missouri, Cole county
gbolten480 Offline
gbolten480  Offline
I'm all for seeing more pics - this sounds like a great build & a fun way to go racing!
Re: SS/DA cuda progress [Re: gbolten480] #1091466
10/10/11 09:02 PM
10/10/11 09:02 PM
Kingsville, Md
grncpe Offline OP
grncpe  Offline OP
Kingsville, Md
That pic was from about april.so I will dole out some progress picks
Re: SS/DA cuda progress [Re: Locomotion] #1091467
10/10/11 09:08 PM
10/10/11 09:08 PM
Kingsville, Md
grncpe Offline OP
grncpe  Offline OP
Kingsville, Md
yes I thought about the offset spring kit.I dont know how much they would stand up to power wise.I allready have the whole cal-trac suspension for it.Split mono leaf,bars,shocks.I dont know how the offset stuf would work with the cal-trac stuff either.I dont know if there is enough room for the front bracket & the front cal-trac bracket.Thanks for your ideas though I have been battling the whole way through this project on trying to keep it mild.
Re: SS/DA cuda progress [Re: gbolten480] #1091468
10/10/11 09:11 PM
10/10/11 09:11 PM
Kingsville, Md
grncpe Offline OP
grncpe  Offline OP
Kingsville, Md
I am going to just keep putting out the early ones so you have to wait!
Re: SS/DA cuda progress [Re: gbolten480] #1091469
10/14/11 04:38 PM
10/14/11 04:38 PM
Kingsville, Md
grncpe Offline OP
grncpe  Offline OP
Kingsville, Md
more?
Re: SS/DA cuda progress [Re: gbolten480] #1091470
10/14/11 04:39 PM
10/14/11 04:39 PM
Kingsville, Md
grncpe Offline OP
grncpe  Offline OP
Kingsville, Md
& more
Re: SS/DA cuda progress [Re: gbolten480] #1091471
10/14/11 04:43 PM
10/14/11 04:43 PM
Kingsville, Md
grncpe Offline OP
grncpe  Offline OP
Kingsville, Md
these are from 6 months ago. I have tons of pics.I will keep posting to catch up over the next few days
Re: SS/DA cuda progress [Re: grncpe] #1091472
10/14/11 06:03 PM
10/14/11 06:03 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats gonna be one very cool SS/DA Cuda Tom. Any particular paint scheme in mind. I always remember the SuperStock Tritak & Morgan SS/DA Cuda. Good luck with it. And thanks for the comments about my car. Ron
Re: SS/DA cuda progress [Re: 383man] #1091473
10/14/11 06:12 PM
10/14/11 06:12 PM
Kingsville, Md
grncpe Offline OP
grncpe  Offline OP
Kingsville, Md
Hey Ron, Yes I have a paint scheme.you will have to wait for the finished product.more pics for now!
Re: SS/DA cuda progress [Re: grncpe] #1091474
10/14/11 06:24 PM
10/14/11 06:24 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Re: SS/DA cuda progress [Re: JERICOGTX] #1091475
10/14/11 06:49 PM
10/14/11 06:49 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Ah come on Tom spill the beans on the paint scheme ? Ron
Re: SS/DA cuda progress [Re: grncpe] #1091476
10/14/11 07:25 PM
10/14/11 07:25 PM
Finally a HUSKER again
Moparnut426 Online content
Moparnut426  Online Content
Thats one hell of a nice miter joint!!
Kasey
