Re: Factory brakeline on firewall not pass tech inspection?
[Re: b5 69]
#1091171
10/09/11 11:37 AM
10/09/11 11:37 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I think it's a bit overboard....Are you using slicks?? If so I'm sure a scattershield is required.We've been racing since 1972 and both cars have the brake lines on the firewall in the factory spot and we've never been asked to move them.One car was a 4-speed w/shield.
[Re: Chris2581]
#1091173
10/09/11 11:42 AM
10/09/11 11:42 AM
Posts: 2,286 Hamilton,Ont
72chrgrally
Hamilton,Ont
I've seen it passed many times but I'd rather have it run along the front, personal preference I guess. Steve
Photobucket sucks
[Re: Chris2581]
#1091174
10/09/11 11:53 AM
10/09/11 11:53 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
It may be over board but it is in the rule book. General Sec under brakes. Quote:
Brake lines must be steel, steel braided or DOT approved flexible and routed out side the frame rail, or enclosed in a 16 inch length of 1/8 inch minimum wall steel tubing securely mounted where lines pass the flywheel bellhousing area and not routed in the drive line tunnel.
Says nothing about speed or ET being a factor either.
It is my understanding from reading this that the addition of the scatter shield will not be sufficient to meet the rules.
[Re: WILD BILL]
#1091175
10/09/11 12:58 PM
10/09/11 12:58 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Yeah thats what the rules say but tons of cars wouldnt be allowed to run if enforced.Most cars have the line running on the firewall factory so they would have to boot probally 1/2 that run.Personally I wont run without a scattershield on my 4 speed.Rocky
Chrysler Firepower
[Re: WILD BILL]
#1091177
10/09/11 01:39 PM
10/09/11 01:39 PM
Posts: 7,506 Az
Crizila
Az
First hand experience in 1964. Blew clutch in my 63 Plymouth going in to 3rd. Took out the brake line - single master system. Look Ma, no brakes . Coasted through at 79mph. Tall grass and loooong shutdown saved my butt - and car.
Fastest 300
[Re: b5 69]
#1091181
10/09/11 03:34 PM
10/09/11 03:34 PM
Posts: 25,892 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I used to get hassled about that brake line on a regular basis, "OK I'll replace it" but never did.
[Re: John_Kunkel]
#1091182
10/09/11 03:46 PM
10/09/11 03:46 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Depends on the track obviously but I moved the line on my 4 speed Duster just to be safe. Our local track has trees and old appliances at the end.
[Re: Guitar Jones]
#1091183
10/09/11 04:02 PM
10/09/11 04:02 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I'm not going to deny the rule exist. I just personally think people are reading something into it.
My stock brake line runs across the stock steel firewall. Did in 1965 still does today in 2011. I have always had to do a personal chuckle about this rule. That brake line is no closer a threat than the stock proportioning valve or distribution located inside the frame on all our cars. I looked at this in great length when I moved the master cylinder to the floor. It is outside the inner framerail. This framerail is not on any stock car, it is part of the tube back half. The line in question is not in the tunnel it is several inches up the firewall.
I have personally been to several dozen NHRA sanctioned tracks. The events were not NHRA. I have been to a lot of IHRA tracks also. The NHRA inspector has teched my chassis numerous times and the hood was at home. He looked the car over in general conversation, had nothing to do with the chassis cert. Never once mentioned this brake line. Maybe he just did not see it for the black paint. Would it be a good investment to tube over the line, absolutely. Will it be done anytime soon, probably not. And just for info. The car ran 8.0's in the quarter at a dozen tracks. So it is a little slow. Maybe that is why nothing has ever been said.
Not telling you to do anything un safe. But, I would rather tube the line in its existing location than run it around the K-member where the crank can reach it. Let's say if I were to drive over the crank.
Leon
[Re: XXHEMI]
#1091187
10/09/11 08:51 PM
10/09/11 08:51 PM
Posts: 2,833 Connecticut
FurryStump
Connecticut
I was given two warnings at Lebanon Valley and told not to return without it corrected.
I was told I had to move mine at lvd once and its an auto running mid 12's
