Page 1 of 4 1 2 3 4
Hope this will help contol wheel stands #1090483
10/08/11 03:58 PM
10/08/11 03:58 PM
Salina ks
572_dup2 Offline OP
Back On The Bumper!!
572_dup2  Offline OP
Salina ks
Shawn Jennings
Re: Hope this will help contol wheel stands [Re: 572_dup2] #1090484
10/08/11 03:59 PM
10/08/11 03:59 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
Shawn Jennings
Re: Hope this will help contol wheel stands [Re: 572_dup2] #1090485
10/08/11 04:21 PM
10/08/11 04:21 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
looks kinda weak for that big ole car.hope it works out
Re: Hope this will help contol wheel stands [Re: bonefish] #1090486
10/08/11 04:51 PM
10/08/11 04:51 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
John Calvert says it will work? I know next weekend.
Shawn Jennings
Re: Hope this will help contol wheel stands [Re: bonefish] #1090487
10/08/11 04:58 PM
10/08/11 04:58 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
short would be my concern
home of the
Sox and Martin Hemi Duster
Re: Hope this will help contol wheel stands [Re: HEMIFRED] #1090488
10/08/11 06:45 PM
10/08/11 06:45 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Have you not tried tightening the front shocks, tightening the rear shocks, limiting travel, more tire pressure, bolting weight on the front???
If you can't handle the truth, you're living a lie.......
Re: Hope this will help contol wheel stands [Re: Big Squeeze] #1090489
10/09/11 12:26 AM
10/09/11 12:26 AM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
This was the first time out with double front afco. The first three runs with them went very good. Didnt make any changes to chassis on the last run. Car had been lazy in middle an high gear. Made some some changes an think we found the power we were missing. Should have all parts we hurt back this coming week. Im hoping to go next weekend. Going to tighten front little bit more.
Shawn Jennings
Re: Hope this will help contol wheel stands [Re: 572_dup2] #1090490
10/09/11 09:55 AM
10/09/11 09:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You ran a short single wheelie bar before and it folded
pretzel... if you go to a longer bar you have more
leverage ... plus dont let the car get the momentum
going up
Re: Hope this will help contol wheel stands [Re: MR_P_BODY] #1090491
10/09/11 11:14 AM
10/09/11 11:14 AM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
Shawn, I just went through this same issue. Is your car a four link?
The wheelie bar is not the answer. Just a crutch.
Heres the sequence as I raced through it
http://speedzonemagazine-photo.smugmug.com/Jjk/Sportsman-Action/19031896_KXSsMv#1479560416_vK7jT5d
Was even worse this weekend. but looks to be squared away! PM me and I'll try and help!
SS/DA 1924
Re: Hope this will help contol wheel stands [Re: SSDAcuda] #1090492
10/09/11 11:38 AM
10/09/11 11:38 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Shawn, are you not the same guy that over the last few years was wondering why his car wouldnt do wheelies, changed the motor, trans and so many other things to get it to wheelie and now you want bars? Or to tame them...I dont get it! No disrespect to you just makes me wonder. Hope you get it straightend out.
Re: Hope this will help contol wheel stands [Re: 9 Sec Phill] #1090493
10/09/11 01:35 PM
10/09/11 01:35 PM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
Phil, the way I see it is he wants to do wheelies like the first two passes, but not the third. I can tell you first hand the third pass he made is no way to race.
He has a problem now as the air is getting better (more hp)and needs to tame it while its still in one piece!
And Shawn, by saying you were talking to calvert, I figure you're running caltracs. Try and tighten up the front shock extension. If you have a digital 7 you can retard timing in low gear also, but try the shocks first.
SS/DA 1924
Re: Hope this will help contol wheel stands [Re: MR_P_BODY] #1090494
10/09/11 03:25 PM
10/09/11 03:25 PM
gregsdart Offline
gregsdart  Offline
going up
My thoughts exactly. If you have the ability to move the wheel closer to the track, I would start there. Say about four to five inches off the track surface.
Re: Hope this will help contol wheel stands [Re: gregsdart] #1090495
10/09/11 03:31 PM
10/09/11 03:31 PM
Guitar Jones Online laugh2
going up
leverage is key to not unload the tires. My car has been on these bars hard and the front tires are never more that a foot off the ground and the front end is tied down. I've since adjusted the four link and calmed it down.
Re: Hope this will help contol wheel stands [Re: Guitar Jones] #1090496
10/09/11 11:20 PM
10/09/11 11:20 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
Im pulling 5* out in first gear, have shocks nearly as tight as they will go, it was an AJE sinlge bar i used.
Shawn Jennings
Re: Hope this will help contol wheel stands [Re: 572_dup2] #1090497
10/09/11 11:48 PM
10/09/11 11:48 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
I remember why i quit posting an coming here now.
Shawn Jennings
Re: Hope this will help contol wheel stands [Re: 572_dup2] #1090498
10/10/11 12:15 AM
10/10/11 12:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Why is that
Re: Hope this will help contol wheel stands [Re: MR_P_BODY] #1090499
10/10/11 12:32 AM
10/10/11 12:32 AM
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Why is that
Dont get upset with what I said, im just curious.
Re: Hope this will help contol wheel stands [Re: MR_P_BODY] #1090500
10/10/11 02:42 AM
10/10/11 02:42 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Why is that
Why would you want to come here and post your problems ? Only to find a more than a few fellow racers that repeatedly give some input to try to help in some way. That usually ends up with you ignoring what gets posted or you not responding to anything but what you want to hear.
Or maybe your too thin skinned to play with the big kids.
home of the
Re: Hope this will help contol wheel stands [Re: HEMIFRED] #1090501
10/10/11 03:46 AM
10/10/11 03:46 AM
Chesterfield Twp. Mi.
John Burdine Offline
the way these bars work is Calverts spin on the AJE design, pivot see/saw point in the middle and push down on the rearend, wont unload the tires on a leaf spring/Caltrak car.
Re: Hope this will help contol wheel stands [Re: HEMIFRED] #1090502
10/10/11 09:19 AM
10/10/11 09:19 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
EXACTLY, Fred.....You took the words right out of my mouth.... If someone's smart enough to take good advice, they probably don't need it.....
No offense, but retarding timing to control a wheelstand IS NOT the thing to do......that's a crutch JUST LIKE the wheelie bar...... This is a DRAG RACE so you NEVER, NEVER, NEVER, NEVER kill power unless you're blowing the tires off with the front tires in the air......Now, that's something to be proud of instead of these ghey-azz wheelie vids he keeps posting.....
Back when his junk had no power we tried to tell him but he wouldn't listen for YEARS......now we're trying to help him again, and I'm guessing it'll be YEARS before he figures it out......
Truth is Shawn, most people look at your threads purely for the entertainment value (just like reading Purple Eddy's threads).....not because we think you're so cool because you FINALLY got it into the 8's and you think it needs wheelie bars.....
Page 1 of 4 1 2 3 4
