'74 440 accessory bracket questions #109026
08/22/08 09:42 PM
08/22/08 09:42 PM
Ohio
jensenguy Offline OP
Ohio
Im attempting to figure out the mounting for my alternator on my 440. Unfortunately this has to be kind of a generic question, because im not sure which car the brackets are borrowed from. I initially had A/C, and power steering. There also was an idler pulley on the A/C bracket. I now just have power steering. I have the 4 groove crank pulley, and 2 groove alt. and water pump. Does anyone have pictures of a similar setup? Or advise? If needed I'll take some pictures of what i have, if it will help.
Re: '74 440 accessory bracket questions [Re: jensenguy] #109027
08/23/08 08:31 PM
08/23/08 08:31 PM
florida
74fldart Offline
74fldart  Offline
florida
this is a 400 engine that was once an ac car i believe as it has a 4 groove crank pulley and the power steering brackets are different than a non ac car. so heres a pic of it.
Re: '74 440 accessory bracket questions [Re: 74fldart] #109028
08/24/08 03:05 PM
08/24/08 03:05 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
location of alt itself doesn't need to be moved, just bracket change of location between A/C and non A/C setups, being than non A/C brackets use the A/C compressor bolt locations.
you will notice on Non A/C the bracket fits just right in front of alt, and on A/C cars fits juts right behing teh front "ear" of alt due the deeper alt bracket location on water pump housing to doesn't meet with Compressor bracket
that pic show extra spacers what really are not needed. Without those extra spacers, the rear groove of alt will meet with last rear groove of crank.
another diff stuff is if who made assembly that got some problem with room to fit that later model alt, what is true fits some tight in front of block and head
Re: '74 440 accessory bracket questions [Re: jensenguy] #109029
08/24/08 03:11 PM
08/24/08 03:11 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
pics of what you have will be really helpfull.
A/C belt iddler pulley is not common to find, that makes the hose coming from compressor be diff too to be able to fit the iddler, bing the hose in two sections, instead the one run hose kind.
anyway the iddler pulley doesn't change anything on belt and pulleys setup.
what si true is that non A/C cars use a diff belt setup, being one belt to water pump and alt with crank pulley and the other one runs just to steering pump. For the right setup will need to find the complete pulleys setup. I think 440source.com provides them, also mancini racing.
about Alt brackets between A/C and non A/C as explained abouve even the brackets ( both bottom and top ) are diff, is not really MANDATORY to change since any setup won't change anything on alt location. Just for right setup looking.
the diff on lower bracket is just the extra leg to bolt to engine mount provision and give streng assembly when turn on compressor, due the heavy vibrations this makes because the extra traction for the compressor turned on.
Re: '74 440 accessory bracket questions [Re: NachoRT74] #109030
08/24/08 04:21 PM
08/24/08 04:21 PM
Ohio
Ohio
thanks for the help guys. The bracket i have is quite a bit different than what was pictured above. Ive decided i dont want to run it regardless if i can or not just because it's so ugly. And from what i remember it puts the alternator so far out. Im considering buying one of the cheap non-ac bracket kits and making everything work for now, I probably will invest in the correct pulleys eventually.
Re: '74 440 accessory bracket questions [Re: jensenguy] #109031
08/24/08 05:18 PM
08/24/08 05:18 PM
Eau Claire, WI
ResQ911 Offline
super gas
ResQ911  Offline
super gas
Eau Claire, WI
I just went through this myself. I ended up just ordering all new brackets and pulleys from 440 source and was done with it.
I would recommend you do the same. Stuff was almost cheap and fit perfect.
Re: '74 440 accessory bracket questions [Re: jensenguy] #109032
08/24/08 05:27 PM
08/24/08 05:27 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
The altrenator bracket that you pictured is for the 100 Amp alternator, not the standard, regular, alternator that the other brackets are for.
I have one of those 100 Amp alternators on my engine, and everything lines up just fine with the original 1971 single groove water pump pullie, and double groove crank pullie. (power steering)
RF-4C Phantom 69-370 Zweibrucken, Germany
