Beefing up SB bottom end #1090156
10/07/11 10:21 PM
10/07/11 10:21 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
I'm looking for suggestions on beefing up the bottom end of my SB. It will be 340 main, 3.580 stroke. Should be just under 500 hp.
Just ARP bolts? Stud girdle? Even thought about a partial fill, but I would like to maintain cooling in case I use it for a street motor.
Thoughts appreciated....thanks
Yeah, it's got a smallblock.
Re: Beefing up SB bottom end [Re: 340B5] #1090157
10/07/11 10:23 PM
10/07/11 10:23 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Under 500 I would just roll with stock everything.
Re: Beefing up SB bottom end [Re: 340B5] #1090158
10/07/11 10:33 PM
10/07/11 10:33 PM
Guitar Jones Offline
Good rod bolts and main studs never hurt but other than that I'd say you're fine.
Re: Beefing up SB bottom end [Re: Guitar Jones] #1090159
10/07/11 10:37 PM
10/07/11 10:37 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
As far as rods go I would buy new GOOD ones, thats a given. Wouldnt bother with the stockers.
Re: Beefing up SB bottom end [Re: Hot 340] #1090160
10/07/11 10:54 PM
10/07/11 10:54 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Thanks. I'm good on the rod bolts(ARP 2000)they will be streched properly. I think I'll just use some ARP main bolts, they really don't cost that much and the piece of mind is worth it.
Re: Beefing up SB bottom end [Re: 340B5] #1090161
10/08/11 09:10 AM
10/08/11 09:10 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
So you just bought new rod bolts? You will have to get the rods resized. May as well get new aftermarket rods that come with new rod bolts..
Re: Beefing up SB bottom end [Re: TheOtherDodge] #1090162
10/08/11 10:33 AM
10/08/11 10:33 AM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
K1 rods.
Re: Beefing up SB bottom end [Re: 340B5] #1090163
10/08/11 10:47 AM
10/08/11 10:47 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
solid machine work and balance it, oil systems are pretty good for the most part but use a good pump drive (hardened) you can open up some oil passages to get more oil to the bottom end, full groove mains will provide more oil to the rod's but will sacrifice oil pressure.
Re: Beefing up SB bottom end [Re: dartman366] #1090164
10/08/11 02:15 PM
10/08/11 02:15 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
If I would use full groove mains and the HN series rod bearings for extra clearance, would it sling too much oil up top for the rings to control? I've had good luck w/ the 1/2 groove mains.
Re: Beefing up SB bottom end [Re: 340B5] #1090165
10/08/11 02:23 PM
10/08/11 02:23 PM
Az
Crizila Offline
Crizila  Offline
Az
Wanna play it a little safer, you could consider Billet main caps and studs for the middle 3 - usually the first problem that shows up on a sm blk when making over 500 hp.
Fastest 300
Re: Beefing up SB bottom end [Re: 340B5] #1090166
10/08/11 02:54 PM
10/08/11 02:54 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My 408 is around 550hp, it only has main studs, align honed mains, full groove mains and King aluminum rod bearings on Comp Star H beam rods. The oil passages are drilled and the pump is ported and matched to the main cap. It runs about 60# of pressure at cruise speed, that doesn't worry though, I know the volume is there.
Re: Beefing up SB bottom end [Re: justinp61] #1090167
10/08/11 03:31 PM
10/08/11 03:31 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
How do you get more volume to the bearings without increasing the pressure or galley size?
Re: Beefing up SB bottom end [Re: justinp61] #1090168
10/08/11 03:36 PM
10/08/11 03:36 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I would go with main studs and align hone the mains because the caps can change with studs. As far as bearing I can't see any reason not to just run a standard P bearing set. Drill all the gallerys. If you are only turning 7,000 you may want a high volume depending on your clearances and oiling system. If you are turning higher and have the oil restricted save some power and run a standard pump with a port job. You shouldn't need any hard block. Nothing wrong with a short fill as it will dampen detonation.
Leon
Re: Beefing up SB bottom end [Re: Hot 340] #1090169
10/08/11 03:47 PM
10/08/11 03:47 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I should've been more specific, the oil passages in the block have been enlarged. The pump is a HV.
Re: Beefing up SB bottom end [Re: justinp61] #1090170
10/08/11 03:48 PM
10/08/11 03:48 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Gotcha
Re: Beefing up SB bottom end [Re: 340B5] #1090171
10/08/11 08:05 PM
10/08/11 08:05 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
jeez my boy goes mid 9's stock..u only buy girdles for 440 blocks
Re: Beefing up SB bottom end [Re: fishy340] #1090172
10/08/11 10:49 PM
10/08/11 10:49 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
mine is showing just on 800 hp std caps 2 bolt mains ,studs top and bottom oil gallery enlarged ,71 360 block ,and take note of what leon said
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Beefing up SB bottom end [Re: Leon441] #1090173
10/08/11 11:03 PM
10/08/11 11:03 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Leon
Can you explain the short fill & dampen detonation thing....
Re: Beefing up SB bottom end [Re: emarine01] #1090174
10/09/11 02:39 AM
10/09/11 02:39 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
BCR main caps
Re: Beefing up SB bottom end [Re: emarine01] #1090175
10/09/11 09:57 AM
10/09/11 09:57 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Leon
Take a simple can of juice. Bang on it with a hammer. You will feel the resonance of the hammer all over the can. Fill the can with block filler and hit it with the hammer. Note some block fillers are better than others. Can you tell the difference.
Leon
