Beefing up SB bottom end
#1090156
10/07/11 10:21 PM
10/07/11 10:21 PM
Posts: 1,532 off the grid
340B5
off the grid
I'm looking for suggestions on beefing up the bottom end of my SB. It will be 340 main, 3.580 stroke. Should be just under 500 hp.
Just ARP bolts? Stud girdle? Even thought about a partial fill, but I would like to maintain cooling in case I use it for a street motor.
Thoughts appreciated....thanks
Yeah, it's got a smallblock.
Re: Beefing up SB bottom end
[Re: 340B5]
#1090158
10/07/11 10:33 PM
10/07/11 10:33 PM
Posts: 20,659 in a cattle trailer down by th...
Guitar Jones
Good rod bolts and main studs never hurt but other than that I'd say you're fine.
[Re: Guitar Jones]
#1090159
10/07/11 10:37 PM
10/07/11 10:37 PM
Posts: 3,396 Pa
Hot 340
Pa
As far as rods go I would buy new GOOD ones, thats a given. Wouldnt bother with the stockers.
[Re: Hot 340]
#1090160
10/07/11 10:54 PM
10/07/11 10:54 PM
340B5
off the grid
Thanks. I'm good on the rod bolts(ARP 2000)they will be streched properly. I think I'll just use some ARP main bolts, they really don't cost that much and the piece of mind is worth it.
[Re: dartman366]
#1090164
10/08/11 02:15 PM
10/08/11 02:15 PM
340B5
off the grid
If I would use full groove mains and the HN series rod bearings for extra clearance, would it sling too much oil up top for the rings to control? I've had good luck w/ the 1/2 groove mains.
[Re: 340B5]
#1090165
10/08/11 02:23 PM
10/08/11 02:23 PM
Posts: 7,506 Az
Crizila
Az
Wanna play it a little safer, you could consider Billet main caps and studs for the middle 3 - usually the first problem that shows up on a sm blk when making over 500 hp.
Fastest 300
[Re: justinp61]
#1090167
10/08/11 03:31 PM
10/08/11 03:31 PM
Posts: 3,396 Pa
Hot 340
Pa
, that doesn't worry though, I know the volume is there.
How do you get more volume to the bearings without increasing the pressure or galley size?
[Re: justinp61]
#1090168
10/08/11 03:36 PM
10/08/11 03:36 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I would go with main studs and align hone the mains because the caps can change with studs. As far as bearing I can't see any reason not to just run a standard P bearing set. Drill all the gallerys. If you are only turning 7,000 you may want a high volume depending on your clearances and oiling system. If you are turning higher and have the oil restricted save some power and run a standard pump with a port job. You shouldn't need any hard block. Nothing wrong with a short fill as it will dampen detonation.
Leon
[Re: Hot 340]
#1090169
10/08/11 03:47 PM
10/08/11 03:47 PM
Posts: 11,685 W. Kentucky
justinp61
W. Kentucky
I should've been more specific, the oil passages in the block have been enlarged. The pump is a HV.
[Re: justinp61]
#1090170
10/08/11 03:48 PM
10/08/11 03:48 PM
Posts: 3,396 Pa
Hot 340
Pa
Gotcha
[Re: Leon441]
#1090173
10/08/11 11:03 PM
10/08/11 11:03 PM
Posts: 3,695 nc
emarine01
nc
Leon
Can you explain the short fill & dampen detonation thing....
