Trailer Tires vs Light Truck or Heavy Truck Tires #1089616
10/06/11 08:13 PM
10/06/11 08:13 PM
NE Ohio
Hemi Joe 4911 Offline OP
NE Ohio
Does any one know what the actual truth is about trailer dealers insisting that you MUST buy the more expensive trailer tires and not buying Light Truck or a Heavy Duty Truck tires that you can buy for less money. Will need 4or6 new ones next year, but $800-$1,000 is a lot of $$$$$ - can buy LT Tires for around $500-$600- Thanks HEMI JOE :
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: Hemi Joe 4911] #1089617
10/06/11 08:17 PM
10/06/11 08:17 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
They make trailer tires for a reason. Don't skimp on the trailer by putting truck tires on it.
Is it really worth saving $300-$400 and risk destroying your truck, trailer, cargo, and possibly cars around you, as well as injuring yourself and others?
Earning every penny of that moderator paycheck.
DBAP
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: not_a_charger] #1089618
10/06/11 08:21 PM
10/06/11 08:21 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I ran LTs on my open trailer and never had a problem..
Iv seen more blown out trailer tires than LTs...
I am truckless..
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: 340SHORTY] #1089619
10/06/11 08:29 PM
10/06/11 08:29 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This question comes up pretty often. The first time I saw it I panicked as I have run light truck tires on my car trailer for over 25 years. I gave my trailer tires a good look and couldn't see anything amiss and have kept using them. I also looked at other people who used the stiffer sidewall trailer tires and they seemed to be scuffed more than mine. I watched my tires during backing and the LT tire seems to deflect in the sidewall and not slide (scuff).
I don't know, I think as long as you don't overload whatever tire you have, you'll be okay.
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: 340SHORTY] #1089620
10/06/11 08:29 PM
10/06/11 08:29 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
weight is weight, doesn't matter if it is on a truck or a trailer. No different than the front tires on a truck, they are going along for the ride. Just make sure you use straight tread and not snow tire type tread, one gets hotter than the other, and use the right load range.
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: Dodgeguy101] #1089621
10/06/11 08:34 PM
10/06/11 08:34 PM
Maybe I'm just paranoid. We used to tow heavy equipment with our dump truck when I worked for the city, and we would never consider putting truck tires on the trailer. Maybe if you're just towing a bass boat or a car, it's not as crucial.
DBAP
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: Hemi Joe 4911] #1089622
10/06/11 09:02 PM
10/06/11 09:02 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
You didn't say how much you were hauling. We've used truck tires on our light duty trailers forever. The sidewalls are stiffer on trailer tires, but as long as we've stayed within the capacity of the truck tires, we have not had any problems.
Heavier stuff is a different animal.
Most of the trailer tires I have seen of late, were made overseas and are basically junk.
Master, again and still
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: Dodgeguy101] #1089623
10/06/11 09:36 PM
10/06/11 09:36 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have to disagree strongly. There is definitely a difference in a trailer tire. If your trailer is a single axle no big deal. But a tad um or triple axle trailer those tires are being drug sideways across the pavement and need different sidewall construction. Not even close being the same as a steering axle!!!!
Low air pressure is what destroys trailer tires, plain and simple.
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: Hemi Joe 4911] #1089624
10/06/11 09:40 PM
10/06/11 09:40 PM
Cincinnati, Ohio
Cincinnati, Ohio
What's your stuff worth to you, I have seen many folks on the side of the road with trailer tire trouble. What does that say? Tires on trailers are worked harder than your tow vehicle tires is what it says to me.
I have towed a lot and have seen many LT tires tore up on race trailers at the races with tore up fenders.
What is your stuff worth to you?
Some place in Utah in a I-70 west rest area, 4100 miles this trip with no trailer tire trouble. 41K worth of trailing the last 3 summers with this setup. Have pulled a 49' enclosed with a complete alcohol operation in it for over 100K miles with no trailer tire trouble, honest.
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: Challenger 1] #1089625
10/07/11 12:30 AM
10/07/11 12:30 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
IIRC, LT tires used on a trailer get 85% of the load rating.
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: RobX4406] #1089626
10/07/11 09:20 AM
10/07/11 09:20 AM
CT
mrrandyj Offline
mrrandyj  Offline
CT
In many states it is illegal to use anything besides trailer rated tires on a trailer. If you ever got pulled over by a dot inspector and you have light truck tires on your trailer, you might not be driving away with it.
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: mrrandyj] #1089627
10/07/11 10:28 AM
10/07/11 10:28 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I know several guys that use lt tires on their trailers, not me. I don't like the feel of the trailer with them on it, my trailer has bias tires on it, maybe next time I'll put radials on it.
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: justinp61] #1089628
10/07/11 02:25 PM
10/07/11 02:25 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
My understanding is that the LT tires more flexible sidewalls tend to generate more heat. That plus just the nature of the tire flexing more probably adds to seperation problems. Low tire pressure, I think, causes more problems than anything by allowing the tire to flex. That all being said my trailer has LT tires on it, but I dont pull long distances that gets 'em hot.
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: Jwilli500] #1089629
10/07/11 02:44 PM
10/07/11 02:44 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I looked into this the last time my travel trailer needed tires. I concluded it was not worth the risk to try to save a few $$'s Check the RV forums and decide for yourself.
Personally I will spend a bit more to ensure my safety and the safety of the people on the road around me.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: finadk] #1089630
10/07/11 02:52 PM
10/07/11 02:52 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thank you...
I was behind a old wrecker truck pulling a old open trailer with a dually pickup truck on it. He destroyed one of the tires on the right rear of the trailer. When I came up on him, he was in the hi speed left lane and he was trying to get off the road on the left side and the tread separated and it just missed my rig, I was pissed. I was in one of the middle lanes.
I hope he got checked out by the Colorado DOT sitting on the side of the road with his old, wore out eqquipment making it dangerous for everyone around him. I don't know what happened to the tread that came off and went by me because I was too busy driving on I-25 with like 4 or 5 lanes wide and this bozo was in the hi speed lane. Pissed me off to think what could have happened to my equipment.
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: Challenger 1] #1089631
10/07/11 03:52 PM
10/07/11 03:52 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Challenger1 is 100% correct. There are some Lt tires that are designed for a trailer also. Goodyear makes a 12 ply LT that can be used on a trailer also. Sidewalls are totally different on ST tires, please don't skimp! Your stuff (especially if it's a MOPAR) is too valuable! Jeff
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: Jwilli500] #1089632
10/07/11 06:59 PM
10/07/11 06:59 PM
Cincinnati, Ohio
Cincinnati, Ohio
Low air pressure is really bad for trailer tire because like you said, it makes too much heat and the tire fails.
I have been for 20 years running my trailer tires 10 pounds over what the sidewall says because I like my trailer fenders.
Then a while back I found this on the Tire Rack website. Check it out, most of us travel over 65mph out on the highways. I was in Colorado or Utah this summer and the speed limit was 80 mph!
Goodyear trailer tire tech.
I am still under the legal speed limit in this picture, your tires better be up for it on both your tow vehicle and trailer.
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: Challenger 1] #1089633
10/07/11 07:29 PM
10/07/11 07:29 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Thank you...
1) I'm sorry that I can't afford $100,000 of 'new' equipment rather than the 'old, wore out eqquipment' that I do have.
2) If I got 'pissed' every time I encountered a tire that came apart on a highway, I'd be in that condition all the time.
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: 6PakBee] #1089634
10/07/11 09:17 PM
10/07/11 09:17 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
personally i like a 7:00 15 truck tire--they have a high profile--carry heavy weight and dont blow up when they turn 5 years old----check with a trailer guy--their tires have a date code--just sitting in the sun destroys them----one of my friends is a guy that always buys good stuff--he was told to replace because of the date code and he did---the tires he took off had 1000 miles on them and had tread like new---he set the old tires and wheels next to his garage and offered them to anyone that would take them---but one blew up just sitting there--then everyone was talking about what in the hell was wrong with those tires then another blew up---- within 3 months 3 of the 4 tires blew up just sitting there----bet i got 20,000 miles on my trailer tires--truck and trailer has hauled through 40 states coast to coast and canada to the mexican border more than half the time loaded with no problems----bob
Re: Trailer Tires vs Light Truck or Heavy Truck Tires [Re: Challenger 1] #1089635
10/07/11 09:35 PM
10/07/11 09:35 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
You do realize that the max speed rating for the tires on that rig of yours is 75 MPH assuming you run top shelf tires?
Kevin
