Re: Trailer Tires vs Light Truck or Heavy Truck Tires
[Re: Hemi Joe 4911]
#1089617
10/06/11 08:17 PM
10/06/11 08:17 PM
Posts: 19,968 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
They make trailer tires for a reason. Don't skimp on the trailer by putting truck tires on it. Is it really worth saving $300-$400 and risk destroying your truck, trailer, cargo, and possibly cars around you, as well as injuring yourself and others?
Earning every penny of that moderator paycheck.
DBAP
[Re: not_a_charger]
#1089618
10/06/11 08:21 PM
10/06/11 08:21 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I ran LTs on my open trailer and never had a problem.. Iv seen more blown out trailer tires than LTs...
I am truckless..
[Re: 340SHORTY]
#1089619
10/06/11 08:29 PM
10/06/11 08:29 PM
Posts: 10,741 North Dakota
6PakBee
North Dakota
This question comes up pretty often. The first time I saw it I panicked as I have run light truck tires on my car trailer for over 25 years. I gave my trailer tires a good look and couldn't see anything amiss and have kept using them. I also looked at other people who used the stiffer sidewall trailer tires and they seemed to be scuffed more than mine. I watched my tires during backing and the LT tire seems to deflect in the sidewall and not slide (scuff). I don't know, I think as long as you don't overload whatever tire you have, you'll be okay.
[Re: Hemi Joe 4911]
#1089622
10/06/11 09:02 PM
10/06/11 09:02 PM
Posts: 12,215 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
You didn't say how much you were hauling. We've used truck tires on our light duty trailers forever. The sidewalls are stiffer on trailer tires, but as long as we've stayed within the capacity of the truck tires, we have not had any problems.
Heavier stuff is a different animal.
Most of the trailer tires I have seen of late, were made overseas and are basically junk.
Master, again and still
[Re: Dodgeguy101]
#1089623
10/06/11 09:36 PM
10/06/11 09:36 PM
Challenger 1
Cincinnati, Ohio
weight is weight, doesn't matter if it is on a truck or a trailer. No different than the front tires on a truck, they are going along for the ride. Just make sure you use straight tread and not snow tire type tread, one gets hotter than the other, and use the right load range.
I have to disagree strongly. There is definitely a difference in a trailer tire. If your trailer is a single axle no big deal. But a tad um or triple axle trailer those tires are being drug sideways across the pavement and need different sidewall construction. Not even close being the same as a steering axle!!!!
Low air pressure is what destroys trailer tires, plain and simple.
[Re: Hemi Joe 4911]
#1089624
10/06/11 09:40 PM
10/06/11 09:40 PM
Challenger 1
Cincinnati, Ohio
What's your stuff worth to you, I have seen many folks on the side of the road with trailer tire trouble. What does that say? Tires on trailers are worked harder than your tow vehicle tires is what it says to me. I have towed a lot and have seen many LT tires tore up on race trailers at the races with tore up fenders. What is your stuff worth to you? Some place in Utah in a I-70 west rest area, 4100 miles this trip with no trailer tire trouble. 41K worth of trailing the last 3 summers with this setup. Have pulled a 49' enclosed with a complete alcohol operation in it for over 100K miles with no trailer tire trouble, honest.
[Re: Jwilli500]
#1089629
10/07/11 02:44 PM
10/07/11 02:44 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I looked into this the last time my travel trailer needed tires. I concluded it was not worth the risk to try to save a few $$'s Check the RV forums and decide for yourself. Personally I will spend a bit more to ensure my safety and the safety of the people on the road around me.
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: finadk]
#1089630
10/07/11 02:52 PM
10/07/11 02:52 PM
Challenger 1
Cincinnati, Ohio
Thank you...
I was behind a old wrecker truck pulling a old open trailer with a dually pickup truck on it. He destroyed one of the tires on the right rear of the trailer. When I came up on him, he was in the hi speed left lane and he was trying to get off the road on the left side and the tread separated and it just missed my rig, I was pissed. I was in one of the middle lanes. I hope he got checked out by the Colorado DOT sitting on the side of the road with his old, wore out eqquipment making it dangerous for everyone around him. I don't know what happened to the tread that came off and went by me because I was too busy driving on I-25 with like 4 or 5 lanes wide and this bozo was in the hi speed lane. Pissed me off to think what could have happened to my equipment.
[Re: Challenger 1]
#1089631
10/07/11 03:52 PM
10/07/11 03:52 PM
Posts: 740 Anderson, IN
1969RR
Anderson, IN
Challenger1 is 100% correct. There are some Lt tires that are designed for a trailer also. Goodyear makes a 12 ply LT that can be used on a trailer also. Sidewalls are totally different on ST tires, please don't skimp! Your stuff (especially if it's a MOPAR) is too valuable! Jeff
[Re: Jwilli500]
#1089632
10/07/11 06:59 PM
10/07/11 06:59 PM
Challenger 1
Cincinnati, Ohio
My understanding is that the LT tires more flexible sidewalls tend to generate more heat. That plus just the nature of the tire flexing more probably adds to seperation problems. Low tire pressure, I think, causes more problems than anything by allowing the tire to flex. That all being said my trailer has LT tires on it, but I dont pull long distances that gets 'em hot.
Low air pressure is really bad for trailer tire because like you said, it makes too much heat and the tire fails. I have been for 20 years running my trailer tires 10 pounds over what the sidewall says because I like my trailer fenders. Then a while back I found this on the Tire Rack website. Check it out, most of us travel over 65mph out on the highways. I was in Colorado or Utah this summer and the speed limit was 80 mph! Goodyear trailer tire tech.
I am still under the legal speed limit in this picture, your tires better be up for it on both your tow vehicle and trailer.
[Re: Challenger 1]
#1089635
10/07/11 09:35 PM
10/07/11 09:35 PM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
You do realize that the max speed rating for the tires on that rig of yours is 75 MPH assuming you run top shelf tires?
Kevin
