Pick my intake! Basic 440 motor
#1089180
10/06/11 01:59 AM
10/06/11 01:59 AM
Posts: 1,630 North Central Florida
eightlitermopar
Ok, first off….I know that similar questions have been asked here. However, the search function on here is taking up a lot of time , so here it goes. Which aftermarket dual plane manifold would work best on a stock 440? Now, basic information. 1969 Dodge Coronet 440 motor out of a 1970 Chrysler town and country. Motor hold compression, cranking compression ranging from 125-145 range depending on cylinder. Stock 1970 906 castings with runners cleaned up a bit (burrs and sharp edges removed) We will be putting a FAST fuel injection system on it. HP manifolds with full dual exhaust. Camshaft will be a Comp 268H single grind (.450 lift, 268 deg duration) Keisler TKO 5 speed with 0.64 overdrive 3.91 sure grip rear end. This car is my dad’s, and he is looking for a fun road trip cruiser with some muscle for freeway onramp action. He will not be revving the pi$$ out of it to make power and he won’t be at the track trying to cut tenths of a second off his E.T. We have the stock 4 barrel manifold, but I guess an aftermarket would help a little….OR would it for this combo? I was leaning towards an Edelbrock performer RPM for the intake (my brother has one on this stroker motor and loves it), but we are also worried about hood clearance. I have tried to convince him to go to aluminum heads, but for this combo I am afraid it may hurt his drivability as far as low end torque, the need for headers to make it worth it, etc. What I mean is…I don’t know if the investment would be worth it in this case. Anyway, what do you think? Stocker 4 barrel manifold, Eddy perf RPM, or other? Thanks! eight
Mopar or no car
Re: Pick my intake! Basic 440 motor
[Re: eightlitermopar]
#1089181
10/06/11 02:29 AM
10/06/11 02:29 AM
Posts: 233 vashon island washington
hunterstroble
The performer RPM does fantastic on the dyno shoot outs, however It might be too tall, but with a drop down air cleaner you may be ok. The Mopar m1 dual plain is a good choice as we. My two cents.
1969 Dodge dart 500 stroker
1973 Dodge Challenger 440
[Re: hunterstroble]
#1089182
10/06/11 04:09 AM
10/06/11 04:09 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Holley Street Dominator 1st pick Eddy RPM 2nd pick...
I am truckless..
[Re: hunterstroble]
#1089186
10/06/11 08:33 AM
10/06/11 08:33 AM
Posts: 5,278 San Jose, California
DennisH
Vacation
Vacation
Yep. Drop down and Power-Bulge Hood saved the day.
[Re: Danan]
#1089188
10/06/11 10:48 AM
10/06/11 10:48 AM
Posts: 75,069 U.S.S.A.
JohnRR
U.S.S.A.
In my opinion, you won't see any gains by swapping out the stock manifold. I'd suggest investing the money somewhere else..
I'm with you , anything stock will be fine for this application , if he wants an aluminum intake to save the weight a regular performer, or the CH4B, would probably be a better choice .
[Re: JohnRR]
#1089191
10/06/11 12:26 PM
10/06/11 12:26 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Also agreed. Quote:
Now that is just plain dumb. dumb, dumb.
[Re: Commando1]
#1089192
10/06/11 12:57 PM
10/06/11 12:57 PM
eightlitermopar
I am confused...how would putting fuel injection on a motor be stupid? reliability? increased mileage? Don't have to change out jets everytime we drive 200 miles away from our high elevation? I honestly don't know the answer and I'm not being rude...this is an honest question.... why would fuel injection be dumb? eight [Also agreed. Quote:
Mopar or no car
#1089193
10/06/11 01:11 PM
10/06/11 01:11 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
1. Isn't going to be anymore reliable, 2. won't have increased mpgs (not enough to warrent the cost anyway) and 3 who needs to change jets evey 200 feet of elevation? The money spent on an EFI system would be better spent on new pistons, heads, exhaust...or almost any other upgrade.
[Re: Mr.Yuck]
#1089194
10/06/11 01:23 PM
10/06/11 01:23 PM
eightlitermopar
Correction: It's not 200 feet of elevation. It was 200 miles. Going south 200 miles where we usually go can be over 2000 foot elevation drop.
So my follow up question. At what point would fuel injection be a viable alternative? Aluminum heads, bigger cam, headers? Obviously, I am new to the fuel injection thing, so this is why I am asking. If fuel injection was an option, then I supposed a different intake would be beneficial.
thanks for the input guys
And since we are on the subject, would Eddy Performer RPM heads and headers do anything for a motor this stock-ish?
eight
Mopar or no car
[Re: Mr.Yuck]
#1089195
10/06/11 01:23 PM
10/06/11 01:23 PM
Posts: 1,445 Sterling Heights, Michigan 483...
daniel_depetro
If you are going to switch intake, I'd choose the Edelbrock Performer RPM. Great intake, lightweight and looks nice when painted engine color to match. I put one on our 1968 Dodge Coronet with a 440 4-speed and it clears the hood fine with a Purolator Pure One 4" tall air filter element when using a Moroso 1" drop base 14" round air cleaner. *Note: I do have the Super Bee / R/T bulge hood on the car. As for saying saying fuel injection is a waste of money... While it might not be an immediate gain of power/mileage the 'set it and forget it' aspect of fuel injection is great. As is the ability of instantly tuning the fuel with nothing more then some tweaking on a PC. No removing screws, sticking gaskets, and changing jets.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
#1089197
10/06/11 02:28 PM
10/06/11 02:28 PM
JohnRR
U.S.S.A.
eight
Ignore the comments about your injection want from the peanut gallery , especially the that thinks a Holley is answer for every single carb recommendation ...
In your case with the elevation change , even on a stock engine , fuel injection is a good choice , if it weren't every single car that rolled out of every single showroom would have a holley 4 bbl on it ...
The head change and the headers will help with power production of course , but you'd probably want to use a different cam , etc....
