John Deere break in oil #1088257
10/04/11 12:21 PM
10/04/11 12:21 PM
Finally a HUSKER again
Moparnut426 Offline OP
Has anyone done any reserch on this stuff? I just bought some to add some to my 4240. Well, I bought a gallon for 23.00 its 10w30, and far cheaper than joe gibbs, the comp cams stuff is 5.25 a qt, and you have to ship it inn from summit, or someone. Im going to try this stuff on the 440 I have. John deere recomends 50-100 hrs on this oil depending on how hard the tractor is being used, and since mine is basically a loader tractor for moving bales, im going 100 hrs. It seems like decent stuff, has a lot of zink inn it, and it says right on the back "may be used to break in any rebuilt engine"
Has anyone on here used it? If it works on a my 140hp, 789 lb ft turbocharged diesel, then it should work in any race engine, or street engine I would think.
Kasey
Re: John Deere break in oil [Re: Moparnut426] #1088258
10/04/11 12:51 PM
10/04/11 12:51 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
I have never heard of it.
But then again i live in the city.
Sounds cool, and i bet it will work just fine!
What kind of oil are you supposed to run it after break in?
Re: John Deere break in oil [Re: HEMIDARTS] #1088259
10/04/11 01:34 PM
10/04/11 01:34 PM
John deere dosnt really spec any brand, just to run 15w40 diesel oil after break in.
Kasey
Re: John Deere break in oil [Re: Moparnut426] #1088260
10/04/11 01:40 PM
10/04/11 01:40 PM
tboomer Offline
tboomer  Offline
Not that great of a deal..23.00 a gallon =5.75/quart.. I am pretty sure that it is another brand of oil rebadged for Deere...
Re: John Deere break in oil [Re: tboomer] #1088261
10/04/11 02:07 PM
10/04/11 02:07 PM
Considering how expensive the joe gibbs stuff is, or the fact that you have to order the comp cams stuff, It isnt that terribly priced, and every john deere dealer accross the country has it. I dont think its too bad really.
Kasey
Re: John Deere break in oil [Re: Moparnut426] #1088262
10/04/11 02:21 PM
10/04/11 02:21 PM
California
mickm Offline
mickm  Offline
California
Kasey
are those numbers correct? are tractor type diesels that far apart in hp and torque?
Re: John Deere break in oil [Re: Moparnut426] #1088263
10/04/11 02:50 PM
10/04/11 02:50 PM
MS
redex79 Offline
redex79  Offline
MS
Yep, I use it on my engines. Worked for a Deere dealer for years, used it on all engine rebuilds. It has some outstanding specs. Don't have the specs in front of me, I'll see if i find them.
Truckin Weekend !
70 Dodge Dart Swinger
11 Ram 1500 Laramie 4x4
21 Dodge Durango GT
Re: John Deere break in oil [Re: redex79] #1088264
10/04/11 03:18 PM
10/04/11 03:18 PM
Guitar Jones Online laugh2
I don't know, it may be great oil but there's something that just doesn't seem right about using farm implement oil in my race engine.
Re: John Deere break in oil [Re: mickm] #1088265
10/04/11 03:24 PM
10/04/11 03:24 PM
Yep, and this tractor is only suposed to make 90-110 hp, but dad had a turbo kit from john deere put on it. I can make more, but the tractor really dosnt need it. The hp/torque comes inn at like 1200-1900 rpm, I think its all done at 2200 rpm. Its a 404 ci engine.
Since I have gotten the tractor I have wanted the service history from his dealer there in torrington, but they havent gotten around to sending it to me. I think Im going to call them and have it faxed to me. I enjoy pulling in the local farm class, but they have certain spec requirements, and I need all his service history so Im not illegal, and not supposed to be in a heavier class.
This reminded me to call them...
Kasey
Re: John Deere break in oil [Re: Moparnut426] #1088266
10/04/11 07:53 PM
10/04/11 07:53 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Its good oil, but designed for low RPM and heavy loads on bearings, not the best choice for a high RPM motor, but great for what it was designed for, I run some very good Exxon Mobil "1005" in large industrial engines, but wouldnt use it in a race motor. IMHO anyway
Re: John Deere break in oil [Re: wyoming] #1088267
10/04/11 08:00 PM
10/04/11 08:00 PM
Utah
topbrent Offline
topbrent  Offline
Utah
So would this be a good oil to use for the break-in of flat tappet engines?
What is the Zinc ppm content?
Any other stats available?
Re: John Deere break in oil [Re: topbrent] #1088268
10/04/11 08:08 PM
10/04/11 08:08 PM
MS
redex79 Offline
redex79  Offline
MS
Yes it is. It's 12ppm Zinc. Was more but in the past year or so EPA screwed that up.
Truckin Weekend !
21 Dodge Durango GT
Re: John Deere break in oil [Re: redex79] #1088269
10/04/11 09:08 PM
10/04/11 09:08 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
yes those motors are that far apart..my dump freightliner cummins motor is factory 280hp/1050tq, next yr it will be 350/1450 lol....gotta love the pull of a cummins
Re: John Deere break in oil [Re: earthmover] #1088270
10/04/11 10:21 PM
10/04/11 10:21 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
My N14 is 525hp@2100 rpm (peak is really closer to 1800 rpm) 1850ft/lbs@1200 rpm. The technical term in the old days was "fast torque rise"
That zinc spec I'm assuming was 1200ppm not 12ppm? 1200ppm last time I checked is just SLIGHTLY more than Rotella is at around 1100-1150ppm.
Kevin
Re: John Deere break in oil [Re: Twostick] #1088271
10/05/11 01:01 AM
10/05/11 01:01 AM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
BRAD PENN OIL 10w 30 i broke my motor in on it and run 20 passes on that oil and change it and put 50 passes on a oil change and that oil looked new the best oil i have used and i run ALCOHOL.
Re: John Deere break in oil [Re: Moparnut426] #1088272
10/05/11 01:26 AM
10/05/11 01:26 AM
Az
Crizila Offline
Crizila  Offline
Az
Paying $5+ a quart for break-in oil is a waste of $ IMO. Any good grade of 10-30 / 10-40 petroleum based oil with a zinc additive ( and there is lots to choose from ) will do just fine in almost all applications.
Fastest 300
