Why dont my W-2 gaskets fit ??? #1087775
10/03/11 07:11 PM
10/03/11 07:11 PM
Sherman Texas
The Shocker Offline OP
Sherman Texas
I have a set of 70's production Econo W-2 heads and im running hedman hustler fenderwell headers .One of the gaskets blew the other day ,so i went down and got a set of Mr.Gasket #5939's for W-2 heads and they dont fit my headers pattern.My heads have two sets of patterns for the exhausts .Which gasket set do i need and were do i get them ?The ones that came off of it were Hedman brand ,but didnt have a part # i could see on them . Thanks in advance ...
Re: Why dont my W-2 gaskets fit ??? [Re: The Shocker] #1087776
10/03/11 07:19 PM
10/03/11 07:19 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Somewhere I have some sets of Mopar W2 exhaust gaskets. I can hunt for them if you're interested. Max
Re: Why dont my W-2 gaskets fit ??? [Re: Blucuda413] #1087777
10/03/11 07:32 PM
10/03/11 07:32 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Witch holes are you using on the heads? Stock pattern or w-2? I would guess that since w-2 gaskets didn't work you are using stock pattern.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Why dont my W-2 gaskets fit ??? [Re: The Shocker] #1087778
10/03/11 08:21 PM
10/03/11 08:21 PM
Guitar Jones Offline
There are two different patterns. Standard and spread. Most but not all W2's have the spread pattern. Some have both. You can call Heddman and get the gaskets from them or at least the number and get them through Jegs or Summit.
Re: Why dont my W-2 gaskets fit ??? [Re: 1967dartgt] #1087779
10/03/11 10:34 PM
10/03/11 10:34 PM
Sherman Texas
Sherman Texas
How can i tell what pattern im using ? Im sorry for not being savy with W-2's .Im new to Mopars ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: Why dont my W-2 gaskets fit ??? [Re: Blucuda413] #1087780
10/03/11 10:36 PM
10/03/11 10:36 PM
Sherman Texas
Sherman Texas
Man i would sure buy a set or two if i knew they were the right ones .Thanks for you offer ...
Re: Why dont my W-2 gaskets fit ??? [Re: The Shocker] #1087781
10/03/11 10:52 PM
10/03/11 10:52 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
measure the center to center distance on the center two ports bolt holes..
smaller is standard..
larger is the race...
Tony
70 AARCuda Vitamin C
Re: Why dont my W-2 gaskets fit ??? [Re: 70AARcuda] #1087782
10/03/11 11:22 PM
10/03/11 11:22 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
If you are running headmans you have adaptor plates. The gasket is it the one on the outside of the plate or the inside to the head? The one to the head is what you bought and the other has to be gotten from hedman.
Re: Why dont my W-2 gaskets fit ??? [Re: 1967dartgt] #1087783
10/04/11 06:30 PM
10/04/11 06:30 PM
Sherman Texas
Sherman Texas
Not sure about the "adapter plates" you mentioned .These are my Hedman headers and this is the Hedman gasket (or whats left of )i removed ...
Re: Why dont my W-2 gaskets fit ??? [Re: The Shocker] #1087784
10/04/11 06:31 PM
10/04/11 06:31 PM
Sherman Texas
Sherman Texas
other side
Re: Why dont my W-2 gaskets fit ??? [Re: The Shocker] #1087785
10/04/11 06:32 PM
10/04/11 06:32 PM
Sherman Texas
Sherman Texas
Old gasket
Re: Why dont my W-2 gaskets fit ??? [Re: The Shocker] #1087786
10/04/11 07:22 PM
10/04/11 07:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Old gasket
Your using the stock port gasket... you can get that
gasket at your local parts store but will need some
trimming
Re: Why dont my W-2 gaskets fit ??? [Re: MR_P_BODY] #1087787
10/04/11 09:04 PM
10/04/11 09:04 PM
Sherman Texas
Sherman Texas
Old gasket
trimming
Please dont laugh ,but do you mean to use a regular small block Dodge non W-2 header gasket ? I was a Bowtie ,and Blue Oval guy up till this car ,so im on a beginers level with Mopar stuff ...
Re: Why dont my W-2 gaskets fit ??? [Re: The Shocker] #1087788
10/04/11 10:48 PM
10/04/11 10:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Old gasket
trimming
Yes... you have the same bolt pattern as stock...
so just get the stock gaskets from the parts store
and you will have to trim it to the ports
EDIT
you should be able to get the proper gaskets at your
local Dodge dealer(some carry alot of performance
parts.. you might be able to use a Magnum gasket also
part #P4876102 is the Magnum... P4876103 is the dual
pattern W-2
Re: Why dont my W-2 gaskets fit ??? [Re: MR_P_BODY] #1087789
10/05/11 07:30 AM
10/05/11 07:30 AM
Sherman Texas
Sherman Texas
Thanks Mr P-body ...
