Why dont my W-2 gaskets fit ???
#1087775
10/03/11 07:11 PM
10/03/11 07:11 PM
Posts: 429 Sherman Texas
The Shocker
Sherman Texas
I have a set of 70's production Econo W-2 heads and im running hedman hustler fenderwell headers .One of the gaskets blew the other day ,so i went down and got a set of Mr.Gasket #5939's for W-2 heads and they dont fit my headers pattern.My heads have two sets of patterns for the exhausts .Which gasket set do i need and were do i get them ?The ones that came off of it were Hedman brand ,but didnt have a part # i could see on them . Thanks in advance ...
Re: Why dont my W-2 gaskets fit ???
[Re: Blucuda413]
#1087777
10/03/11 07:32 PM
10/03/11 07:32 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Witch holes are you using on the heads? Stock pattern or w-2? I would guess that since w-2 gaskets didn't work you are using stock pattern.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: The Shocker]
#1087778
10/03/11 08:21 PM
10/03/11 08:21 PM
Guitar Jones
There are two different patterns. Standard and spread. Most but not all W2's have the spread pattern. Some have both. You can call Heddman and get the gaskets from them or at least the number and get them through Jegs or Summit.
[Re: 1967dartgt]
#1087779
10/03/11 10:34 PM
10/03/11 10:34 PM
The Shocker
Sherman Texas
How can i tell what pattern im using ? Im sorry for not being savy with W-2's .Im new to Mopars ...
[Re: Blucuda413]
#1087780
10/03/11 10:36 PM
10/03/11 10:36 PM
The Shocker
Sherman Texas
Somewhere I have some sets of Mopar W2 exhaust gaskets. I can hunt for them if you're interested. Max
Man i would sure buy a set or two if i knew they were the right ones .Thanks for you offer ...
[Re: The Shocker]
#1087781
10/03/11 10:52 PM
10/03/11 10:52 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
measure the center to center distance on the center two ports bolt holes..
smaller is standard..
larger is the race...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1087782
10/03/11 11:22 PM
10/03/11 11:22 PM
1967dartgt
Hilltown Pa
If you are running headmans you have adaptor plates. The gasket is it the one on the outside of the plate or the inside to the head? The one to the head is what you bought and the other has to be gotten from hedman.
[Re: 1967dartgt]
#1087783
10/04/11 06:30 PM
10/04/11 06:30 PM
The Shocker
Sherman Texas
Not sure about the "adapter plates" you mentioned .These are my Hedman headers and this is the Hedman gasket (or whats left of )i removed ...
[Re: The Shocker]
#1087786
10/04/11 07:22 PM
10/04/11 07:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Old gasket
Your using the stock port gasket... you can get that gasket at your local parts store but will need some trimming
[Re: MR_P_BODY]
#1087787
10/04/11 09:04 PM
10/04/11 09:04 PM
The Shocker
Sherman Texas
Old gasket
Please dont laugh ,but do you mean to use a regular small block Dodge non W-2 header gasket ? I was a Bowtie ,and Blue Oval guy up till this car ,so im on a beginers level with Mopar stuff ...
