70 RR Dash- air grabber location? #1087626
10/03/11 02:57 PM
10/03/11 02:57 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
My lower dash piece was broken so I purchased one from a member here. Whats odd is the hole for the airgrabber is in a different location ( lower..) See photo.. any ideas?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 70 RR Dash- air grabber location? [Re: JMCFAN] #1087627
10/03/11 04:23 PM
10/03/11 04:23 PM
okla.
O
okie Offline
okie  Offline
O
okla.
My dash piece was trashed and I had to get another one and the hole was different on it so I don't think they tried to get them all the same. Ronnie
Re: 70 RR Dash- air grabber location? [Re: okie] #1087628
10/03/11 04:57 PM
10/03/11 04:57 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
It could be that it varied by assembly plant, transmission, or part to part.
Re: 70 RR Dash- air grabber location? [Re: 6bblgt] #1087629
10/03/11 04:58 PM
10/03/11 04:58 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
"E" - LA assembled, 4-spd, 204 SPD
Re: 70 RR Dash- air grabber location? [Re: 6bblgt] #1087630
10/03/11 05:54 PM
10/03/11 05:54 PM
USA
b54406barrel Offline
USA
You might try a search. Someone was restoring a 70 rr & I recall there were several responses on that switch & location(s) of the hole(s). Was in the last year, I'm pretty sure.
Re: 70 RR Dash- air grabber location? [Re: JMCFAN] #1087631
10/03/11 06:15 PM
10/03/11 06:15 PM
Washington State
70_FY1_N96_BEEP Offline
Washington State
Just did mine. But I purchased one with no hole because the locations were put in on the fly so to speak on assembly. I have 2 ralley dash frames and they're both different locations. For mine, I mounted the finish bezel, then tranferred the dash frame HOLE and screw locations onto the back of bezel. Then removed the bezel and did the SQUARE cutout and drilled the 2 holes. For yours, I'd do the same, except transfer the SQUARE cutout onto the dash frame, elongate the exsisting hole and drill 2 new holes provided there is ample excess for the new location. Or find another bezel with no hole and start fresh. I know of a black bezel with no hole in Idaho at this moment. Good luck, shouldn't be a hard fix.
