Kill switch rating #1087044
10/02/11 10:12 PM
10/02/11 10:12 PM
Indiana
O
Osyman Offline OP
Osyman  Offline OP
O
Indiana
I'm putting a normally open momentary switch between my starter relay and the NSS. What current rating does that need to be? I figure I should be able to get away with 10A rated switch?
Re: Kill switch rating [Re: Osyman] #1087045
10/03/11 07:59 AM
10/03/11 07:59 AM
If you have a 10 amper on hand I'd use it, should be plenty for that circuit
Re: Kill switch rating [Re: RapidRobert] #1087046
10/03/11 08:09 AM
10/03/11 08:09 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
x2, however you can check the load on that wire if you wanted to. Just power the control circuit of the starter relay with a meter and see how much it pulls.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
