Racing w/ a column shifter/ manual valve body? #1086968
10/02/11 07:35 PM
10/02/11 07:35 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Looking at another car for street/strip. My trans has a 904 w/ a Griner trans brake (Reverse pattern). Easy enough to swap to a forward manual valve body, but may take some getting used to. Going for the sleeper look.
Ideas?
Re: Racing w/ a column shifter/ manual valve body? [Re: Scamp451] #1086969
10/02/11 08:15 PM
10/02/11 08:15 PM
K
KOS Offline
KOS  Offline
K
why not leave it reverse pattern?you dont have to worry bout hittin Neutral on the way up.had one in a mid 11sec ride worked great.
Re: Racing w/ a column shifter/ manual valve body? [Re: KOS] #1086970
10/02/11 09:46 PM
10/02/11 09:46 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
The '65 A990 cars came from the factory with a modified column and reverse valve body. The '66 I am building is also setup this way, and I plan on leaving it like that.
Re: Racing w/ a column shifter/ manual valve body? [Re: sixpakdodge] #1086971
10/02/11 09:58 PM
10/02/11 09:58 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
My Green D100 is forward pattern on the column with a bench seat, and that's how I race it...Not easy, but you get used to it.
Re: Racing w/ a column shifter/ manual valve body? [Re: Dragula] #1086972
10/02/11 10:21 PM
10/02/11 10:21 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
I run my 69 Dart with a forward pattern manual VB and column shift it with the stock linkage and shifter. I like the clean stock look of it also. "Wheelsup68" Lonnie drives my car in pro in the mopower series and he seems to like it too. Just like driving when we were younger
Re: Racing w/ a column shifter/ manual valve body? [Re: G-Money1320] #1086973
10/02/11 11:42 PM
10/02/11 11:42 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Can you do anything to the column shift to improve it and prevent over shifting or hitting neutral?
Re: Racing w/ a column shifter/ manual valve body? [Re: Scamp451] #1086974
10/03/11 04:18 PM
10/03/11 04:18 PM
Cleveland Ohio
Discoquik Offline
Discoquik  Offline
Cleveland Ohio
I used a reverse pattern valvebody in my 71 Valiant 4-door for the same stealthy reasons. Pulled the column apart without removing the whole unit from car. This way you can mock up the detent as you remove and recheck to sneak up on where to stop in relation to the transmissions detent and gear indicator on the column. There is a detent held in with two philips screws that shifter pawl rides on. I ground the 2nd gear "step" over to make 1st (now 3rd gear)so you pulled back towards you for high gear.
So basically I would slap second down with two fingers and pull back for third while hanging onto the steering wheel with my thumb. Never messed up a shift because, when I modified the column, I used a dremel with a small cutting disc to make the detent have a nice sharp 90 degree edge to the pawl. A regular disc cutter would have put too gently of a radius in it. I think it would have wanted to "walk" to 3rd during race conditions.
Free and failsafe. I have to give Mel Enders credit for telling me how to do it. He went one step further and had his speedometer "mapped" out by MPH "shift points" with two small hash marks, so his 64 Valiant sleeper had no speed gadgets inside...pretty cool car that one was.
Re: Racing w/ a column shifter/ manual valve body? [Re: Scamp451] #1086975
10/03/11 07:54 PM
10/03/11 07:54 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
As an alternative, you could make adjustments to the governor and shift springs to have it shift automatically as well.
Re: Racing w/ a column shifter/ manual valve body? [Re: Discoquik] #1086976
10/04/11 09:39 AM
10/04/11 09:39 AM
Wi.
old_racer Offline
old_racer  Offline
Wi.
I did this to mine also, been racing it for years. also did a friends nhra stock elim car the same way. hard to see in the picture but I relabled the indicator p-r-n-1-2-3. turned out slick.
Russ
Re: Racing w/ a column shifter/ manual valve body? [Re: old_racer] #1086977
10/04/11 09:55 AM
10/04/11 09:55 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
...just put a PUSH BUTTON shifter in it ...
Re: Racing w/ a column shifter/ manual valve body? [Re: dOc !] #1086978
10/04/11 10:03 AM
10/04/11 10:03 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Themz be too new fer pushy buttons
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Racing w/ a column shifter/ manual valve body? [Re: old_racer] #1086979
10/04/11 11:25 AM
10/04/11 11:25 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
anyone have a pic of the mod to the detent in the column? i've been wanting to do this to my car but can't visualize what to do. i also use a reverse manual vb with bench seat and column shift
Re: Racing w/ a column shifter/ manual valve body? [Re: dirtybee] #1086980
10/04/11 11:33 AM
10/04/11 11:33 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I left mine on the column. Run 11 ohs. Reverse manual. I've always liked it. No pesky cable to give you fits. Its all mechanical linkage.
Re: Racing w/ a column shifter/ manual valve body? [Re: hemi-itis] #1086981
10/04/11 11:37 AM
10/04/11 11:37 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
NO SO ... 'itis ..
A PB shifter is good for any occasion ...
ONE is going in my Caravan ..
BTW ...yurr shifter is on the uNcorrect side ... a DOUBLE 2 U .!
Re: Racing w/ a column shifter/ manual valve body? [Re: Scamp451] #1086982
10/05/11 12:04 PM
10/05/11 12:04 PM
Mid-Michigan
GOREO Offline
GOREO  Offline
Mid-Michigan
Been using that setup on all 3 of my Dart's over the years. Keep the shift linkage snug with fresh bushings. I flipp the trans shift rod over to get better clearance with my TTI headers.Use only a MSD shift light on the column once I know the best shift rpm. Looks clean and almost stock.
