b-body housing in an a-body??? #108697
08/21/08 10:14 PM
08/21/08 10:14 PM
Camp LeJeune, NC
USMCBuckWild Offline OP
Camp LeJeune, NC
Someone told me this evening that i can get a b-body 8 3/4 housing onto stock width a-body springs. He said that you drop one on the pin, bolt it down and push the springs apart to fit the other pin. Only an inch difference in pad width. Says with properly back-spaced wheels, this works great in an a Duster? Is this true?
If so i'll be
It ain't illegal unless you get caught!
Re: b-body housing in an a-body??? [Re: USMCBuckWild] #108698
08/21/08 10:16 PM
08/21/08 10:16 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Yes it's true.
Sheldon
Re: b-body housing in an a-body??? [Re: USMCBuckWild] #108699
08/21/08 10:21 PM
08/21/08 10:21 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Yup, it's true.
I did it to a 69 dart.
Easiest on a duster/demon, as the wheel wells are open, and the tire clearance doesn't become an issue.
66-67 B body is the narrowest B housing (just less than 1" wider on the perches, and about 1" total width difference) so find one of them, and have at 'er.
Re: b-body housing in an a-body??? [Re: USMCBuckWild] #108700
08/21/08 10:26 PM
08/21/08 10:26 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
The 65-67 B-rears are the narrowest of the bunch, and the best fit in an A-body. Go ahead and relocate the perches to A-body width to keep all your existing wheel well space, or go for another 3/4" with a kit from DoctorDiff and others to max out without cutting. An 8" wheel with about 5.75" backspace should be a real nice fit, and you could go wider in a Duster if you measure closely.
Clair
