Re: Blended fuel going bad ! [Re: VernMotor] #1085523
10/05/11 11:24 AM
10/05/11 11:24 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Looks like phase separation, All ya need is humid air and time with ethanol blends, Buy a gallon from BP... put it in a clear bottle... and wait a few weeks, the stinky crap on the bottom is your problem... if ya take it one step further... store some in a metal coffee can and see what it does to the bottom of the can A quik tip for blending... Dig up a clean 50 gal fuel drum & fill with mix, Keep in cool dry place away from direct sun light, Do not vent, Draw fuel from the middle of the drum for racing, Every couple of weeks test the bottom of the barrel and pump off the ugly stuff < use the ugly stuff to kill fire ants > If you store in the cars tank install a low point drain and drain off the ugly stuff before ya fire the engine then nail the ants We run a small 2 gal fuel tank, I run it dry after racing and fill with 1 gal AV gas then prime & fire it up, It coats everything with lead, try not to get the AV gas on you, it kills more than ants
Re: Blended fuel going bad ! [Re: emarine01] #1085524
10/05/11 07:30 PM
10/05/11 07:30 PM
Western,Pa.
MagnumDartSport Offline
Western,Pa.
I used to mix Sunoco 110 with 93 octane pump gas and I had the same problem. When I quit mixing the problem went away. I talked to quite a few people(including one chemist for a local oil refiner)and they all blame it on the ethanol in the pump gas.
Re: Blended fuel going bad ! [Re: MagnumDartSport] #1085525
10/06/11 04:28 AM
10/06/11 04:28 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
gotcha---
i will try to find some non / low Ethanol pump next week
Re: Blended fuel going bad ! [Re: 493_DART] #1085526
10/06/11 03:39 PM
10/06/11 03:39 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Last summer I started draining the fuel cell between races and storing the fuel in sealed containers in a cool place. Modern gas goes bad quickly in an unsealed container. I've been using E25, blending pump 92(E10) and E85 and had no crud or corrosion at all.
2 times in a row recently, i have had all my fuel go bad from the car sitting 3 or 4 weeks .
I blend Bp 92 with Sunoco 110 , half-n-half.
Any thoughts ? Is it from blending ?
Re: Blended fuel going bad ! [Re: @#$%&*!] #1085527
10/06/11 06:29 PM
10/06/11 06:29 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Interesting mix.... .... Can you provide more info.... jetting, ratios tried, timing, any temp change, power results ect...
Re: Blended fuel going bad ! [Re: emarine01] #1085528
10/06/11 07:14 PM
10/06/11 07:14 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I used to run my Valiant on BP 92. I found that if it got more than a couple weeks old it would even be changing color in a sealed jug. The car would slow down almost 1/2 second in the 1/4 until I put new fuel in.
Re: Blended fuel going bad ! [Re: slantzilla] #1085529
10/06/11 07:42 PM
10/06/11 07:42 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
We mix our gas 3 gallons race(112) and 2 gallons (91). We have been racing over 20 years and we put 250 runs plus a year on our cars( we race 2 different cars) and have NEVER had any issues with seperation slowing down or any nonsence like that.I have not raced for over a month and the gas in my fuel jugs looks like the day i put it in there. If you store your gas in direct sunlight it will turn colors.
Re: Blended fuel going bad ! [Re: WheelsUp73] #1085530
10/11/11 09:48 PM
10/11/11 09:48 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
took the carb apart today . i cleaned it up before the last race---this is the result of the car sitting for 8 days !!
Re: Blended fuel going bad ! [Re: 493_DART] #1085531
10/11/11 10:35 PM
10/11/11 10:35 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Look how rusted the a/p diaphragm is? Has to be moisture in the mix, at least at first glance.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Blended fuel going bad ! [Re: 493_DART] #1085532
10/11/11 10:43 PM
10/11/11 10:43 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i bought a carb off ebay a year ago, when i got it, i was like, wow, this carb is brand new. when i took it apart it looked just like your picture times 10. after i cleaned it all up, it was all pitted like the carb was being eatin away. i rebuilt it, sold it to someone i knew and it works fine but the metering blocks were so bad i thought i may need to replace them. it probably didnt work at all for the guy who had it before i got it.
Re: Blended fuel going bad ! [Re: kilroy] #1085533
10/11/11 10:44 PM
10/11/11 10:44 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i think he should try some drygas every tank & see how bowels look then. stay safe, seeya.
Re: Blended fuel going bad ! [Re: kilroy] #1085534
10/11/11 11:01 PM
10/11/11 11:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep, thats water
Re: Blended fuel going bad ! [Re: MR_P_BODY] #1085535
10/11/11 11:10 PM
10/11/11 11:10 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
well, im going to use different pump gas, and buy some race gas at the track.
and see what happens...
maybe my car will pick up with "proper" fuel in it
