Re: Blended fuel going bad !
[Re: VernMotor]
#1085523
10/05/11 11:24 AM
10/05/11 11:24 AM
Posts: 3,695 nc
emarine01
nc
Looks like phase separation, All ya need is humid air and time with ethanol blends, Buy a gallon from BP... put it in a clear bottle... and wait a few weeks, the stinky crap on the bottom is your problem... if ya take it one step further... store some in a metal coffee can and see what it does to the bottom of the can A quik tip for blending... Dig up a clean 50 gal fuel drum & fill with mix, Keep in cool dry place away from direct sun light, Do not vent, Draw fuel from the middle of the drum for racing, Every couple of weeks test the bottom of the barrel and pump off the ugly stuff < use the ugly stuff to kill fire ants > If you store in the cars tank install a low point drain and drain off the ugly stuff before ya fire the engine then nail the ants We run a small 2 gal fuel tank, I run it dry after racing and fill with 1 gal AV gas then prime & fire it up, It coats everything with lead, try not to get the AV gas on you, it kills more than ants
[Re: 493_DART]
#1085532
10/11/11 10:43 PM
10/11/11 10:43 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
took the carb apart today . i cleaned it up before the last race---this is the result of the car sitting for 8 days !!
i bought a carb off ebay a year ago, when i got it, i was like, wow, this carb is brand new. when i took it apart it looked just like your picture times 10. after i cleaned it all up, it was all pitted like the carb was being eatin away. i rebuilt it, sold it to someone i knew and it works fine but the metering blocks were so bad i thought i may need to replace them. it probably didnt work at all for the guy who had it before i got it.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: kilroy]
#1085534
10/11/11 11:01 PM
10/11/11 11:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Look how rusted the a/p diaphragm is? Has to be moisture in the mix, at least at first glance.
Yep, thats water
