Buying a cam for a Magnum with mech. fuel pump? #108501
08/21/08 06:01 PM
08/21/08 06:01 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
In the Hot Rod issue where they build a 5.9L Magnum with an LA front case and belt drive, here's what they say:
Magnum engines featured a serpentine-belt accessory drive, a reverse-rotation water pump, and utilized a timing-case cover with no provision for a mechanical fuel pump. The Magnum camshaft nose was also changed and will not accept a mechanical fuel-pump drive eccentric. An LA-series timing case will bolt directly to a Magnum block, allowing mounting for the fuel pump, conventional accessories, and a standard LA-engine water pump in a retrofit application. The camshaft will also need to be ordered on a core with the LA-series nose to accept the fuel-pump eccentric.
The part I am most worries about is this: "The camshaft will also need to be ordered on a core with the LA-series nose to accept the fuel-pump eccentric."
What do they mean? Can I just purchase an LA-series camshaft, or will it not be correct? Thanks.
Re: Buying a cam for a Magnum with mech. fuel pump? [Re: sharpie] #108502
08/21/08 06:04 PM
08/21/08 06:04 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Magnums cams have a different snout on them that doesn't really allow a fuel pump eccentric.
Should be able to stick an LA cam into a magnum engine.
Re: Buying a cam for a Magnum with mech. fuel pump? [Re: RobX4406] #108503
08/21/08 06:30 PM
08/21/08 06:30 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
That's what I'd like to confirm. The article doesn't say, and I know I'll need to buy the eccentric and such, I just don't want to mess up a $300 order.
Re: Buying a cam for a Magnum with mech. fuel pump? [Re: RobX4406] #108504
08/21/08 06:30 PM
08/21/08 06:30 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
What about using a... linky linky
Re: Buying a cam for a Magnum with mech. fuel pump? [Re: OzHemi] #108505
08/21/08 06:38 PM
08/21/08 06:38 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
ah, thank you Jeff! that might be the way to go; I can use the stock cam for now
edit: though now that I look at that part, it looks like a magnum cam will fit into the 1987-02 (which that part's designed for), so that means an LA cam should slide into the Magnum block?
Re: Buying a cam for a Magnum with mech. fuel pump? [Re: sharpie] #108506
08/21/08 06:39 PM
08/21/08 06:39 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
No prob
Re: Buying a cam for a Magnum with mech. fuel pump? [Re: sharpie] #108507
08/21/08 08:47 PM
08/21/08 08:47 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
yup. the TBI LA's had a short snout, too. an LA cam and magnum cam are more or less identical, except carbed cams have the longer snout for a fuel pump eccentric, and LA cams have the #2 and #4 cam journals drilled to get oil up to the heads. OEM magnums typically don't....
2017 Grand Cherokee Overland
Re: Buying a cam for a Magnum with mech. fuel pump? [Re: patrick] #108508
08/22/08 01:52 AM
08/22/08 01:52 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I have a Hughes snout extension kit on my Magnum & works great. 27,000 miles so far without fail.
Re: Buying a cam for a Magnum with mech. fuel pump? [Re: BulletBob] #108509
08/22/08 07:17 AM
08/22/08 07:17 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
The first cam I put in my magnum was a cam cut at CamMotion. The cam I have in it now is a MP purple 501/513 with the long snout. It is the circle track cam. Works pretty good for my combo. Hughs has cams for you with the long snout. You can get new cores or regrinds that are about half the cost. They have the springs to match the stick you want also.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Buying a cam for a Magnum with mech. fuel pump? [Re: StandOnIt] #108510
08/22/08 01:22 PM
08/22/08 01:22 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Hughes sells and adaptor to fit an fuel pump eccentric on a Magnum cam.
Re: Buying a cam for a Magnum with mech. fuel pump? [Re: sharpie] #108511
08/22/08 03:41 PM
08/22/08 03:41 PM
Tri-Cities, Washington
V
VITC_GTX Offline
VITC_GTX  Offline
V
I got my cam from Scott Brown and I asked him to grind a cam with the fuel pump eccentric. No problems or extra costs
Re: Buying a cam for a Magnum with mech. fuel pump? [Re: VITC_GTX] #108512
08/25/08 11:17 AM
08/25/08 11:17 AM
dogdays Offline
dogdays  Offline
Use a Carter P4070 Street Pump and you don't have to worry about the mechanical pump.
R.
