Re: 4 spd 833 help, braking front bearing retainer.
[Re: Steve Barton]
#1084837
09/29/11 12:54 AM
09/29/11 12:54 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I would think that 1 arm is hanging up and pushing sideways when you release the clutch... that pressure plate would have to go(or change the arm)
[Re: MR_P_BODY]
#1084839
09/29/11 01:08 AM
09/29/11 01:08 AM
Posts: 151 Canada BC
Steve Barton
Canada BC
this is a new $2500.00 clutch ass.
[Re: Steve Barton]
#1084840
09/29/11 01:12 AM
09/29/11 01:12 AM
MR_P_BODY
IMO... right now you have a $2500 piece of trash... if that arm is hanging up and pushing on the slider its going to cause havoc on any bearing
[Re: MR_P_BODY]
#1084841
09/29/11 10:36 AM
09/29/11 10:36 AM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
Can you loosen the bolt up for the pivot of that 3rd arm on the pressure plate and attempt to slide it inboard any?
Also a really dumb question (assuming with a slickshifted gearset and a $2500 clutch it's been done already), but have you centered the bellhousing to the crank?
[Re: Blusmbl]
#1084843
09/29/11 11:39 AM
09/29/11 11:39 AM
Steve Barton
Canada BC
Yes with in .004"
[Re: Steve Barton]
#1084844
09/29/11 09:41 PM
09/29/11 09:41 PM
Posts: 1,169 MI
68shifter
MI
Did you have any luck having the manufacturer take a look at your assembly.
It sure looks like the short lever is riding on the very edge of the to bearing and I cannot see how it wouldn't side load and cause your candlestick problems.
Any drag with clutch disengagement or anything or just when it's "broke". That's a Youngblood unit correct?
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: Steve Barton]
#1084846
09/29/11 10:13 PM
09/29/11 10:13 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Steve I would send these pics to Rob(it looks like one his plates) because it clearly has one lever too short.This is what is causing the retainer to break without a doubt It is pushing the T.O.bearing off to one side and just plain breaking it off.I have a billet retainer for a 23 spline unit if you need one send me a PM Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 68shifter]
#1084847
09/30/11 12:12 AM
09/30/11 12:12 AM
Steve Barton
Canada BC
Yes it is robs clutch, he does not want me to send him the clutch back, his opinion is that the short arm has nothing to do with my problem but he is sending me a lever to make me happy.
[Re: fourgearsavoy]
#1084848
09/30/11 12:23 AM
09/30/11 12:23 AM
Steve Barton
Canada BC
I have sent all these pics and many more to Rob, He is standing his ground saying no way its my problem, he is sending me a lever so that I will be happy even though (it wont help me). I already have a billet retainer to put in this time,as well as a larger T,O bearing, thanks.
[Re: Steve Barton]
#1084851
09/30/11 09:11 AM
09/30/11 09:11 AM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
He may not think it's causing the retainer to break but it is definitely an issue because the leverage with the shorter arm is different than the other 2 .
[Re: 6PACMAC]
#1084852
09/30/11 11:41 AM
09/30/11 11:41 AM
Steve Barton
Canada BC
How is your pilot bushing in the back of the crank?
Its a bearing style and it is perfect.
