Need pic of cuda antenna base installed #1084146
09/28/11 08:37 AM
09/28/11 08:37 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Morning all, as the topic states I need pic of a cuda antenna base installed specifically the trim ring my new one puts mine at an angle?
Re: Need pic of cuda antenna base installed [Re: UCUDANT] #1084147
09/28/11 11:10 AM
09/28/11 11:10 AM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
The new trim ring I bought for my Challenger wasn't shaped right. I had to have my original one rechromed.
Re: Need pic of cuda antenna base installed [Re: burdar] #1084148
09/28/11 06:03 PM
09/28/11 06:03 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I bought Dales Cuda shops P/N ANTKN1Y. Anyone got a pic of a correct E body Cuda antenna ring installed so I can compare? Maybe I am doing something wrong but theres a lip on one side of the ring that forces the antenna to tilt. I used Dales Cuda shop for the antenna because of a few folks said to get it there. I can post a pic of the part when i get home this evening
The chrome guy called to say he wants an extra $100 for the bumperettes ..... nothing is easy and yes it does get old. I think that I may just install the glass and cover it for awhile
Re: Need pic of cuda antenna base installed [Re: UCUDANT] #1084149
09/28/11 06:49 PM
09/28/11 06:49 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
My repop does that too.
Re: Need pic of cuda antenna base installed [Re: jbc426] #1084150
09/28/11 09:28 PM
09/28/11 09:28 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I can't accept an incorrect part, if it has my antenna at an angle. So whats up with this base? Did I do something wrong?
Re: Need pic of cuda antenna base installed [Re: UCUDANT] #1084151
09/29/11 07:26 AM
09/29/11 07:26 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Wow, mine's not that bad. The top of the mast is only off to the side an inch or two.
Re: Need pic of cuda antenna base installed [Re: UCUDANT] #1084152
09/29/11 11:16 AM
09/29/11 11:16 AM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
its not the bezel, its the position of the zinc bracket that the cable is attached to underneath. the only way to do this properly is to thread the antenna in and use it to turn the bracket under the panel and with your other hand gently try to push the part of the bezel that sticks out into the notch of the bracket underneath. its takes a few times before you get the right position. or take the cable assembly out altogether and test fit everything on the bench so you know where the notch on the bracket should be positioned so the bezel will sit correctly. good luck
Re: Need pic of cuda antenna base installed [Re: UCUDANT] #1084153
09/29/11 12:23 PM
09/29/11 12:23 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
That is obviously not right. I cannot help you as mine has the factory top bezel but the rest of the antenna is a disguised two way radio antenna. They were used in the era by undercover cops from BNDD, FBI and other groups with initials for surveillance. I am using it for amateur radio. It has been on the car since 1979.
Craig
Re: Need pic of cuda antenna base installed [Re: 70plymA34] #1084154
09/29/11 09:17 PM
09/29/11 09:17 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
No way The nut has to sit in the bezel so the bezel forces the angle...period
Re: Need pic of cuda antenna base installed [Re: UCUDANT] #1084155
09/29/11 09:25 PM
09/29/11 09:25 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Re: Need pic of cuda antenna base installed [Re: denfireguy] #1084156
09/29/11 09:39 PM
09/29/11 09:39 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Craig
My bezel is a survivor. It is much flatter than yours.
Craig
Re: Need pic of cuda antenna base installed [Re: denfireguy] #1084157
09/29/11 09:42 PM
09/29/11 09:42 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Thanks that's exactly what I was after.... the part
Re: Need pic of cuda antenna base installed [Re: denfireguy] #1084158
10/03/11 12:26 PM
10/03/11 12:26 PM
ohio
dalescudashop Offline
ohio
Any chance of getting a picture of the other side?
Re: Need pic of cuda antenna base installed [Re: dalescudashop] #1084159
10/03/11 12:43 PM
10/03/11 12:43 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
The underside
Re: Need pic of cuda antenna base installed [Re: UCUDANT] #1084160
10/03/11 12:44 PM
10/03/11 12:44 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
this is the issue though, note the angle of the recess/collar around the hole ie the seat for the nut is at a 45 degree angle, just like an AAR
Re: Need pic of cuda antenna base installed [Re: UCUDANT] #1084161
10/03/11 12:45 PM
10/03/11 12:45 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Here's the nut sitting in the seat. Package says DCS 70-74 Cuda except AAR antenna bezel ANTBZ1
Re: Need pic of cuda antenna base installed [Re: UCUDANT] #1084162
10/03/11 01:04 PM
10/03/11 01:04 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
looks more like an A body one to me
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: Need pic of cuda antenna base installed [Re: UCUDANT] #1084163
10/03/11 06:22 PM
10/03/11 06:22 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I wish I had a dime for every repop part that I've seen mis-packaged, broke,or defective...Point is don't take the packaging as a guide here...You already know it's not the correct part...I bet the seller never looked in the box to actually confirm the contents...Send Dale's the pic you've posted here and get the correct one...
Re: Need pic of cuda antenna base installed [Re: screamindriver] #1084164
10/03/11 07:08 PM
10/03/11 07:08 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
That's already done
Re: Need pic of cuda antenna base installed [Re: UCUDANT] #1084165
10/05/11 11:52 PM
10/05/11 11:52 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
New bezel, they list this as the AAR bezel
