cam bearings too tight #1083878
09/27/11 08:50 PM
09/27/11 08:50 PM
California
mickm Offline OP
mickm  Offline OP
California
got the block back from the machine shop, and the cam wouldn't go in. took it back, and we started playing with it. out of the block, bearings fit nicely on the cam. in the block, 3 out of the 5 were too tight. we did a lot of playing around, but finally i had to leave.
this is a mopar hemi (not world) mega block.
in the end, he found that all the holes were .0005 to .001 too small, and so were crushing the bearings when they were inserted in the block.
i brought him an old cam, and he grooved the journals on the lathe, and then inserted the cam and made 1 turn and removed it. buffed the bearings with scotchbrite, and now the cam fits like a dream!
how common is this on these blocks? i've heard of issues with these before, but all of the holes to be too small?
also the hole to the driver side head from the #4 bearing did not match perfectly, so i had him enlarge the hole in the bearing so it is completely open.
anything else i should be aware of here??
Re: cam bearings too tight [Re: mickm] #1083879
09/27/11 08:53 PM
09/27/11 08:53 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive heard quite a few that were tight.A good machinist shop should check them.Thats why they really need the cam if they install the bearings.The oil holes are the same.Some line up great some not so good.Rocky
Chrysler Firepower
Re: cam bearings too tight [Re: therocks] #1083880
09/27/11 08:57 PM
09/27/11 08:57 PM
California
mickm Offline OP
mickm  Offline OP
California
i didn't bring him the cam initially. i should have brought it, he should have asked
but he took care of me...
Re: cam bearings too tight [Re: mickm] #1083881
09/27/11 08:58 PM
09/27/11 08:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats quite common to have to size the bearings...
I have a cam for that purpose laying around here
Re: cam bearings too tight [Re: MR_P_BODY] #1083882
09/27/11 09:00 PM
09/27/11 09:00 PM
California
mickm Offline OP
mickm  Offline OP
California
well at least i have one now too!
Re: cam bearings too tight [Re: mickm] #1083883
09/27/11 09:34 PM
09/27/11 09:34 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Can you post a pic of the cam? Im trying to see what you did incase I run into this...
Re: cam bearings too tight [Re: Hot 340] #1083884
09/27/11 11:34 PM
09/27/11 11:34 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Had a problem with my 440 block when I built my 493. I put the # 1 and 5 cam bearings in and the cam turned fine so I installed the bearings one at a time. I found # 3 bearing had a scratch mark on the back of it as it had a small piece of metal rolled into the cam bearing bore making the bearing high at that spot. I looked where the bearing scratch was and found the protruding metal and removed it. Fixed it right up. Ron
Re: cam bearings too tight [Re: mickm] #1083885
09/27/11 11:46 PM
09/27/11 11:46 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
#80 grit wet/dry is your friend.
8.30's @3400 lbs
Re: cam bearings too tight [Re: Hot 340] #1083886
09/27/11 11:47 PM
09/27/11 11:47 PM
California
mickm Offline OP
mickm  Offline OP
California
i will get the block and cams back in the next day or so. i'll post some pics when i get my hands on it.
Re: cam bearings too tight [Re: mickm] #1083887
09/28/11 04:18 PM
09/28/11 04:18 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
I use red scotch brite and WD 40 to massage the bearings. Also check the cam on V blocks and a dial indicator to make sure its not bent
Re: cam bearings too tight [Re: mickm] #1083888
09/28/11 06:24 PM
09/28/11 06:24 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
if you have more than 1 core to use maybe cut each cam bearing serface of like a puck so you can check them indevidualy also.
Re: cam bearings too tight [Re: Hot 340] #1083889
09/28/11 07:51 PM
09/28/11 07:51 PM
Az
Crizila Offline
Crizila  Offline
Az
One I just did for a sm blk. Cut the grooves in each journal on an angle and slanted towards the leading edge ( as you would rotate the cam bolt - clockwise ). Chamfered the trailing edge of each groove and stoned the leading ( cutting )edge.
Fastest 300
Re: cam bearings too tight [Re: Crizila] #1083890
09/28/11 09:36 PM
09/28/11 09:36 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I get it now. How much stock on the bearing can you safely take out?
Re: cam bearings too tight [Re: Hot 340] #1083891
09/29/11 11:58 AM
09/29/11 11:58 AM
California
mickm Offline OP
mickm  Offline OP
California
this is what he did. took some material off to one side of the groove to accumulate the removed bearing material. this works, although i like crizilla's better.
he put it in and gave it 1 turn, and that was enough to clearnace them properly, although i think he did a few more to be sure. then scothbrite and away we go!
Re: cam bearings too tight [Re: mickm] #1083892
09/29/11 03:13 PM
09/29/11 03:13 PM
Missouri, Cole county
gbolten480 Offline
gbolten480  Offline
I personally like the ingenuity that is shown on this topic & have experienced this on a second gen hemi block manufactured in 2005. At the following site - Mike Ware sheds a little light on the topic. Hope it helps. Right side column - down a bit.
http://www.musclemotorsracing.com/muscle-mike-blog.html
Re: cam bearings too tight [Re: gbolten480] #1083893
09/29/11 04:44 PM
09/29/11 04:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
OK, the bearing bores in the block are undersized from the factory so that begs the question "what did the factory do?" The answer is they either scraped them or bored them.
I don't like the idea of using any abrasive material like Scotchbrite, sandpaper, hone, etc. due to the possibility of impregnating the soft babbit with grit.
Re: cam bearings too tight [Re: John_Kunkel] #1083894
09/29/11 05:27 PM
09/29/11 05:27 PM
California
mickm Offline OP
mickm  Offline OP
California
that also begs more modern questions. like if this is a known issue, why can't the factory just get it right on these newer blocks? it is obviously a simple machine setting issue, because the bores are not too big, or all over the place, they are always too small, and almost always by the same amount.
makes sense. i would think that just going over them lightly as a final cleanup wouldn't do any harm though. one would hope...
