Type Of Wood For Carb Heat Shield
#1083555
09/27/11 07:33 AM
09/27/11 07:33 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
I am looking at making another carb heat shield and I want to make the next one out of wood. What kind of wood do I need to make this out of? I was hoping to go by my local Loews or Menards and pick something up and just transfer my existing lexan template onto. I am looking at maybe 1/4" or 5/16" thick for the new shield. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Type Of Wood For Carb Heat Shield
[Re: YO7_A66]
#1083556
09/27/11 08:10 AM
09/27/11 08:10 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
do you have a local hobby store near you? if so get a piece of the plywood for models. otherwise I would use some Marine plywood. I would think that a normal board would crack..
I am truckless..
[Re: Mr.Yuck]
#1083558
09/27/11 08:27 AM
09/27/11 08:27 AM
YO7_A66
Indiana
Why? I am on my second polycarbonate (Lexan) heat shield and it just cracked over the weekend and I want to try making one out of wood this time. I have a good template that I can just lay over some wood and trace around it and start cutting, but I need to find out what type of wood to use.
Note: I do have a local specialty wood distributor that I have contacted and I am waiting for a reply. But they may not have a small enough piece. Thanks for the replies.
[Re: YO7_A66]
#1083560
09/27/11 09:33 AM
09/27/11 09:33 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
wow never had one crack. Had a 1/2" 4 hole for years on a Supercharged 440 and no issues. You might be able to by a wooden one pre-made. I have seen them but it's been years.
[Re: Mr.Yuck]
#1083561
09/27/11 09:46 AM
09/27/11 09:46 AM
YO7_A66
Indiana
This is not for a carb spacer but for a carb heat shield/carb heat deflector. You can see one of my earlier Lexan shields in this picture. I am on my fourth revision of it now and I need another material. My current one is painted with a black wrinkle finish to match my air cleaner. The paint helps protect it when gas comes out of the bowl during jet changes. The gas is probably what helped cause the cracking with the Lexan. Thanks
[Re: YO7_A66]
#1083562
09/27/11 10:28 AM
09/27/11 10:28 AM
Mr.Yuck
Brookeville, Md
Ohhhhh... I used the aluminum Holley unit for years. Might still have it someplace.
[Re: RapidRobert]
#1083564
09/27/11 10:45 AM
09/27/11 10:45 AM
YO7_A66
Indiana
I am currently receiving emails from a local sawmill. They are helping me with the wood selection for this application. I will give an update once I have decided on a wood that they carry. So far the prices are very cheap and they ship too.
[Re: YO7_A66]
#1083565
09/27/11 10:51 AM
09/27/11 10:51 AM
RapidRobert
Been trying to remember & just coming with "cabinet grade" something. I'd think it'd be easy to do with a table jig saw just trace out the gasket pattern then cut the "square" out on the inside and a little deburring
[Re: 62maxwgn]
#1083568
09/27/11 11:43 AM
09/27/11 11:43 AM
Posts: 969 OH--IO
360904
OH--IO
[Re: 69sixpackbee]
#1083570
09/27/11 02:32 PM
09/27/11 02:32 PM
YO7_A66
Indiana
After discussing the different wood options, the best option for heat, gas, and not cracking is the Baltic Birch Plywood. I can get a 30" x 30" x 1/4" piece for a whopping $9.00 plus shipping. This will leave me plenty of material left for more changes in the future.
Note: I asked about the Marine Fir Plywood and his response was that the glues are better but the wood is not as hard and it would absorb more fuel. He suggested that I use a urethane coating on the Marine plywood.
The above "Cool Carb" parts appear to be very nice. Thank you for posting that information.
Thanks again for your replies.
