Autometer speedometer #108339
08/21/08 12:37 PM
08/21/08 12:37 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
I have a Autometer speedo and the factory cable will not bolt up to the back of the gauges. What I need is a cable with both ends that screw in instead of one side slipping on. Anyone else run into this problem. What cable did you use? I have a sb 727 by the way. Thanks
Re: Autometer speedometer [Re: Shatar4] #108340
08/21/08 01:09 PM
08/21/08 01:09 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
i had this same problem on mine
i got a monster speedo and couldnt hook it up was told to get a cable from a late 60,s early 70,s chevy truck so thats what i did
ralph
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Autometer speedometer [Re: Shatar4] #108341
08/21/08 01:10 PM
08/21/08 01:10 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
A cable from a '66 will work. Got an Autometer speedo in my '66 Charger and it hooked right up.
Re: Autometer speedometer [Re: Shatar4] #108342
08/21/08 01:25 PM
08/21/08 01:25 PM
Redding, CA
RDJ Offline
RDJ  Offline
Redding, CA
If you want to go the cheap route, you can get a cable for a 66 dart at Kragen Auto or something, it is threaded at both ends (I have a 904 though) for like $10. It is 80" long though, which is a little on the long side. A more expensive but better fitting one can be ordered from www.imperialservices.net
Re: Autometer speedometer [Re: Shatar4] #108343
08/21/08 01:25 PM
08/21/08 01:25 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Re: Autometer speedometer [Re: Devil] #108344
08/22/08 11:28 AM
08/22/08 11:28 AM
Hightstown, NJ
njdevil2 Offline
njdevil2  Offline
Hightstown, NJ
Got one from Lokar. It was a cut to fit. Worked great.
1970 road runner Convertible
1 of 179
Re: Autometer speedometer [Re: njdevil2] #108345
08/22/08 11:41 AM
08/22/08 11:41 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Re: Autometer speedometer [Re: In_The_Pink] #108346
08/22/08 06:37 PM
08/22/08 06:37 PM
Nebraska
71blueduster Offline
super street
super street
Nebraska
I just swapped in a set of Autometer gauges in the Duster a couple months ago. O'Riellys had a speedometer cable for a 67 B-Body that has the proper ends on it to screw onto the gauge. And I think it was less than $12. I don't have the part number or the box it came in, but it shouldn't be hard to find.
