Trans help needed! #108324
08/21/08 12:16 PM
08/21/08 12:16 PM
south jersey
W
welderboy Offline OP
W
south jersey
Have an early 904 trans going to a '72 /6 - problem is new converter hub measures about 1.55" and crank end is 1.81". Can't use a later converter because spline count is different. Any thoughts? Thanks!
Re: Trans help needed! [Re: welderboy] #108325
08/21/08 06:36 PM
08/21/08 06:36 PM
south jersey
W
W
south jersey
bump....
Re: Trans help needed! [Re: welderboy] #108326
08/21/08 07:31 PM
08/21/08 07:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There are reducer rings available, can't remember who offers them; or have one made locally.
Re: Trans help needed! [Re: John_Kunkel] #108327
08/21/08 08:07 PM
08/21/08 08:07 PM
www.wildcatauto.com the last one I purchased from them was $20 to my door.
Re: Trans help needed! [Re: RapidRobert] #108328
08/22/08 07:57 AM
08/22/08 07:57 AM
south jersey
W
W
south jersey
Thanks John and Robert - made a midnite run to the shop where I used to work and made a spacer from a 3000 psi socket weld fitting.
