2 step button on brake pedal #1082909
09/26/11 11:13 AM
09/26/11 11:13 AM
Tallmadge, Ohio
Butch Offline OP
Butch  Offline OP
Tallmadge, Ohio
Lets see your 2 step setup on brake pedal please.
Pictures and part numbers if possible.
Butch
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: 2 step button on brake pedel [Re: Butch] #1082910
09/26/11 12:09 PM
09/26/11 12:09 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Before I put in my trans brake I just wired my two step into the stop light switch on the brake pedal.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: 2 step button on brake pedel [Re: 67HEMI] #1082911
09/26/11 10:25 PM
09/26/11 10:25 PM
Tallmadge, Ohio
Butch Offline OP
Butch  Offline OP
Tallmadge, Ohio
Great idea, any more?
'74 Duster 440
'06 Pacifica
'78 MGB
Re: 2 step button on brake pedel [Re: Butch] #1082912
09/27/11 08:56 AM
09/27/11 08:56 AM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Used this starter button that you'd normally mount on firewall for valve adjustments.
Hold it when footbraking on the line and when you launch it releases the low side and activates the high rpm side of the 2 step.
Just have to not step on it when braking at the finish line, so place it where you are comfortable with your feet!
Re: 2 step button on brake pedal [Re: actionange] #1082913
09/27/11 11:10 AM
09/27/11 11:10 AM
Tallmadge, Ohio
Butch Offline OP
Butch  Offline OP
Tallmadge, Ohio
Perfect thanks
'74 Duster 440
'06 Pacifica
'78 MGB
Re: 2 step button on brake pedal [Re: Butch] #1082914
09/27/11 07:37 PM
09/27/11 07:37 PM
Louisville, KY
Allan_G Offline
Allan_G  Offline
Louisville, KY
Butch, I'll suggest an alternative that allows you to keep a cleaner look and not have to worry about stepping on it when you don't want to. Just plumb a tee into your brake line and install a pressure switch. I used a switch from NAPA, though I don't have the part number handy. I plumbed mine into the rear line. Worked great! I have a pic of it somewhere. If I can find it, I'll post.
-Allan
(FKA Racer Al back in 2000...)
Re: 2 step button on brake pedal [Re: Allan_G] #1082915
09/27/11 08:19 PM
09/27/11 08:19 PM
Tallmadge, Ohio
Butch Offline OP
Butch  Offline OP
Tallmadge, Ohio
I like that idea even better. I hope you can find the picture.
Butch
'74 Duster 440
'06 Pacifica
'78 MGB
