Re: power window regualtor bushing......where to get?
[Re: TX9H6E4CUDA]
#1082500
09/25/11 09:11 PM
09/25/11 09:11 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Possibly from a non-power window regulator? To replace it I'd expect to grind the back side of that special attaching rivet & to reattach either weld or or there is clearance you might be able drill through that rivet & use a nut/bolt..
[Re: 1_WILD_RT]
#1082501
09/25/11 10:28 PM
09/25/11 10:28 PM
Posts: 5,796 minnarusta
TX9H6E4CUDA
minnarusta
Ugh!!!! Ill have to look at some regualtors in my attach to see if they are the same or not. I thought it might of been a common problem. The reason I think this one is broke because some of mounting bolts are "gone" and the regulator was able to move around and put pressure on the bushing. Oh well one more thing on the list to do
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
[Re: TX9H6E4CUDA]
#1082502
09/25/11 10:43 PM
09/25/11 10:43 PM
TX9H6E4CUDA
minnarusta
Well just look at a challenger manual regulator and no bushing .......darn now im gonna see if a diplomat one will have it.
[Re: TX9H6E4CUDA]
#1082503
09/26/11 04:58 PM
09/26/11 04:58 PM
TX9H6E4CUDA
minnarusta
Well I went and looked at a diplomat version and no dice. This is going to be fun to find a good one and replace it. Anyone else ever have this problem?
[Re: TX9H6E4CUDA]
#1082504
09/26/11 05:40 PM
09/26/11 05:40 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
You may wind up having to make it out of steel.. When you posted I recognized the part but wasn't 100% sure it's power window E & 71 up B body only but at this point I think thats pretty clear... You might be able to sandwich a couple pieces of 12 ga or 14 ga sheet metal to make the proper shape & act as a spacer like the original part... A couple plug welds would keep it squared up & it wouldn't ever break again...
[Re: 1_WILD_RT]
#1082505
09/26/11 09:26 PM
09/26/11 09:26 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
OK I was at my shop earlier, I don't know what regulator you looked at, I looked at a pair of E body manual front regulators & those bushings are used... Shouldn't be to tough to get...
