When to color sand and polish after fresh paint? #1081966
09/25/11 02:52 AM
09/25/11 02:52 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
How long should be the wait after painting and clear to sand and polish?
Re: When to color sand and polish after fresh paint? [Re: lahatte] #1081967
09/25/11 09:12 AM
09/25/11 09:12 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It can be done in 24 hours most times. I just did some and waited 48 hours. Sooner you do it, the easier it sands imo. Some clears dry really hard, get it done earlier, imo.
Re: When to color sand and polish after fresh paint? [Re: Challenger 1] #1081968
09/25/11 09:53 AM
09/25/11 09:53 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
yup, most say after 24 hours. wait a day or 2 and you'll be fine.
the longer you wait though, the harder the clear is going to get.
**Photobucket sucks**
Re: When to color sand and polish after fresh paint? [Re: 70Cuda383] #1081969
09/25/11 10:12 AM
09/25/11 10:12 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And while there is merit to that idea I've seen stuff move around as the solvents evaporate.. Most have flashed within 24 hours but some take longer.. I prefer to wait two weeks & just realize it's gonna be allot of work... Maybe the best Idea is to cut it open with 1500, shave any runs, work any dirt specks then leave it alone a couple weeks before coming back with 2000 then 3000 Trizact & a final polish..
Re: When to color sand and polish after fresh paint? [Re: 1_WILD_RT] #1081970
09/25/11 10:21 AM
09/25/11 10:21 AM
Cincinnati, Ohio
Cincinnati, Ohio
If it was baked it's ready to go for sure in 24 hours imo.
My 71 was not baked and he did it the next day and it is still flawless today.
Paint day,
The next day,
Re: When to color sand and polish after fresh paint? [Re: 1_WILD_RT] #1081971
09/25/11 12:25 PM
09/25/11 12:25 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
...with Randy, best to cut the paint, minimum 1000 grit about after a week of painting the car, i like to let it sit about 3 to 4 more weeks to "gas out" any solvents, esp dark colors, because buffing the paint seals the surface somewhat, and further gas out may take place if you buff too soon, causing the paint to "texture" again,...I like to finish wet sanding from 1000 to 1500, then 2000, then 2500, and up to 3000, if you take the car to 2500, it's just polish and your done, anything less, and it's compound, then polish,...the 3M Finessit line is my prefered finishing system
Mike
Re: When to color sand and polish after fresh paint? [Re: Challenger 1] #1081972
09/25/11 12:55 PM
09/25/11 12:55 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
When I was learning to paint I had a hood that I color blended and after the second coat was baked I color sanded an area and as the top surface was smoothed out the bottom layer that was trapped ran. I was disappointed but learned a good lesson. So even baked you can have trapped solvents that have not cured.
Re: When to color sand and polish after fresh paint? [Re: DAYCLONA] #1081973
09/25/11 01:45 PM
09/25/11 01:45 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Mike
I kind of like it when the paint "retextures", you get more of a factory appearing enamel then. I'm talking real fine texturing. Unless you want the smooth as wet glass look that isn't anything like what the cars looked like when new.
Re: When to color sand and polish after fresh paint? [Re: hemi70se] #1081974
09/25/11 02:48 PM
09/25/11 02:48 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have observed a couple garage paint jobs that have been sanded and buffed out the next day and they look perfect, but a few weeks later they start showing cloudiness, sanding scratches, and minor orange peel in the clearcoat. What is weird is it's not consistant over the whole car, but just random patches of it here and there.
The production body shops I familiar with here wet sand one time and then use heavy compounds to get the shine out of it. The cars look nice out in the sunlight when the customer picks them up, but under garage lighting they are full of flaws.
Re: When to color sand and polish after fresh paint? [Re: Neil] #1081975
09/25/11 03:07 PM
09/25/11 03:07 PM
Cincinnati, Ohio
Cincinnati, Ohio
I would wait maybe a little longer but not month or anything like that. Luckly my car was only in my painters shop for 10 days, so things moved fast.
Sanding scratches come from imperfections in the body work. And leting cure isn't gonna help with those? are they?
Production body work is different yet from what we expect on our collector/classic cars.
I was showing my wife the diffrence on her freshly repaired Durango from a friends body shop who does a lot of work around here. It looked fine, but if you look real close you could see a difference between factory and his work. It matched color wise, just the texture and smoothness is different. I didn't want to pay him anymore, it was good enough for her and I.
Re: When to color sand and polish after fresh paint? [Re: Challenger 1] #1081976
09/25/11 08:30 PM
09/25/11 08:30 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
What waiting does is allow time for the paint to gas out so nothing moves after you do your final cut & buff.. You can color sand out super minor imperfections that are in the bodywork if your are confident in how much material you have but at the very least you can soften the imperfection & make it much less noticeable.... For those who do allot of Color sanding (Dayclona) if you haven't all ready I suggest trying the Trizact, it has it's place whether being used as a final pass before polishing a flat as glass job or being used to match a factory peel the stuff really is a time saver...
Re: When to color sand and polish after fresh paint? [Re: 1_WILD_RT] #1081977
09/25/11 10:03 PM
09/25/11 10:03 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Thanks for sharing all the good tips.
Also, if anyone is so inclined, I would be very interested to see the list of supplies and order of application that work well for you.
