Suspension mods for street vs strip #1081642
09/24/11 06:31 PM
09/24/11 06:31 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I was looking at getting some of the hotchkis suspension parts for my cuda to replace the factory ones. Mainly, I was looking at the sway bars but if I was to put a set of their 1.03" torsion bars in, how much would this hurt the cars weight transfer and affect the cars ability to launch? This will be a street/ strip car so I'm kind of stuck between building the car to doth both. Thanks for any help.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Suspension mods for street vs strip [Re: 73cuda340] #1081643
09/25/11 08:05 AM
09/25/11 08:05 AM
the house on the left.
cogen80 Offline
cogen80  Offline
everything is a compromise one way or another. figure out what way you want the car to be more( street or track). then deal with it taking a hit on the other.
Re: Suspension mods for street vs strip [Re: cogen80] #1081644
09/25/11 10:25 AM
09/25/11 10:25 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
You can always remove the swaybars at the track and with adjustable shocks make the necessary tweak there. The only thing you;re really stuck with are springs per se. You could set up a suspension that you can adjust for both. You wont get the best of both worlds, but you wont miss the best either.
Re: Suspension mods for street vs strip [Re: POS Dakota] #1081645
09/25/11 11:16 AM
09/25/11 11:16 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
FWIW you can just rebuild your stock stuff w/ good hardware and bushings and you'd be suprised how well it handles. If you just want a bigger sway bar try a PST unit. They are much cheaper, nothing against hotchkis but that stuff is $$$ and is mainly for guys that run road courses.
At the track (drag) you can always unbolt you front sway bar links for more transfer.
Coming soon!!!!
Re: Suspension mods for street vs strip [Re: Mr.Yuck] #1081646
09/25/11 12:12 PM
09/25/11 12:12 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
I am kinda following what Rick E. did with the 69 Road Runner in Mopar Action. The car runs 11 second 1/4 mile times turns and stops well.
Im currently digging through my old issues and ordering up the ones I am missing. Go online at mopar action and some of the info is there.
Like has been said before its all a compromise. With the current motor technology out there among other things having a car that does most of the above is possible.....unless you need a car that goes deep into the 10's or faster and also corners with the kids in the back seat eating ice cream with the dvd's playing for them with the a/c cranking.
Re: Suspension mods for street vs strip [Re: PHJ426] #1081647
09/25/11 12:36 PM
09/25/11 12:36 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Ice cream in the car is out of the question, but the availability of hydraulic roller cams, stroker kits, and great aftermarket heads give us the power. Caltracs with split monoleafs, great shocks, Firmfeel's swaybars, upper control arms and power steering box mods, US Cartool subframe connectors and modern tire technology(like 325/ 50 15 Nitto 555r's) that provides mind-boggling traction; give us control of the road AND the ability to launch. Don't forget to add Perfect fit Vintage Air A/C with a hidden compressor kit from Bouchillion, a few bulk packs of well placed Dynamat Extreme and cocoon up the rest of the interior with rolls of The Insultor Mat from AirCraft Spruce and some aluminum tape.
These days we can have our cake and eat it too, ala-mode if you like.
Re: Suspension mods for street vs strip [Re: jbc426] #1081648
09/25/11 05:41 PM
09/25/11 05:41 PM
clarks summit pa
clarks summit pa
I'm not looking at building an autocross car. I would much rather have it be able to launch better than to take corners faster. I just was looking to improve on the handling a little but wasn't sure if it would be a big difference with the torsion bars added. Would this hurt alot of the cars ability to transfer weight or would it only be a small difference?
Re: Suspension mods for street vs strip [Re: 73cuda340] #1081649
09/25/11 07:28 PM
09/25/11 07:28 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
JBC --- I like the way the Cuda stands with them Nitto's one bad ride there.
Re: Suspension mods for street vs strip [Re: PHJ426] #1081650
09/25/11 07:30 PM
09/25/11 07:30 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
I have a .960 T bar on my 72 Runner it weight transfers fine with a 4.30 gear out back and a set of super stock springs with Drag Radials.
Re: Suspension mods for street vs strip [Re: 73cuda340] #1081651
09/25/11 07:32 PM
09/25/11 07:32 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
That 1.03" is a pretty stiff T-bar so the front won't rise much at all, but it should handle corners and dips well
Re: Suspension mods for street vs strip [Re: 451Mopar] #1081652
09/25/11 07:43 PM
09/25/11 07:43 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Firm Feel, USCartool subframe connectors, and 4 Hotchkis-tuned Bilstein shocks alone made a dramatic difference in handling on the 69 Coronet. Hotchkis bars are reported to be hollow (I think) making them lighter and better performing than stock originals. They are on my list.
Re: Suspension mods for street vs strip [Re: 73cuda340] #1081653
09/26/11 11:05 AM
09/26/11 11:05 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
IMO, build it to be better mannered on the street than the strip. Will it imapcts its ability to transfer weight, yes. What will the impact be, maybe 2 or 3/10 of a second. We aren't talking huge differences here. Most street strip cars are far from having the ultimate drag strip suspension anyway, so giving up a couple more tenths for a safer street vehicle is no big deal. On top of that, you are likely running it as a bracket car. In this case, consistantcy is far more important the ultimate e.t. The firmer street suspension will be more consistent run after run compared to an all out drag set up.
Re: Suspension mods for street vs strip [Re: PHJ426] #1081654
09/26/11 01:29 PM
09/26/11 01:29 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I think there's a Cadillac that can do that...
**Photobucket sucks**
Re: Suspension mods for street vs strip [Re: TC@HP2] #1081655
09/26/11 07:28 PM
09/26/11 07:28 PM
clarks summit pa
clarks summit pa
I'm not running it as a bracket car, just something that I can have fun with on the street and still put down some good times at the strip. The main reason Im so concerned about hurting the cars traction is because I have a 528 hemi in the car; so I can use every bit of help in the traction department.
Re: Suspension mods for street vs strip [Re: 451Mopar] #1081656
09/26/11 07:39 PM
09/26/11 07:39 PM
P
Pauls69 Offline
super gas
Pauls69  Offline
super gas
P
i have the MP 1" bars on mine & would never go back. it rides & handles like a completely different car. the steering is still vague, but much of the understeer/plowing is gone. kinda wish i would have bought a larger bar now.
Re: Suspension mods for street vs strip [Re: 73cuda340] #1081657
09/27/11 01:12 PM
09/27/11 01:12 PM
Sante Fe Springs, CA
Hotchkis Offline
Hotchkis  Offline
73Cuda340 – Having a Hemi in your Cuda is really sweet! Obviously however you decide to build the car is up to you, but as TC pointed out…building a car with better manners on the street makes for a car is so much more fun to drive. We get lots of coverage of our customer cars on the autocross track, but mostly because that’s a good way to demonstrate how well the cars handle. In reality, 90% of our customers don’t ever turn a wheel in anger, they simply want their car to have better road manners on the street. Our system improves overall feel and control without a punishing ride. So the next time you hop out of your modern daily driver and into your Mopar muscle car, you get modern handling with the power and sound we all love.
Here’s a double duty Challenger owned by a Hotchkis H-Team member:
Re: Suspension mods for street vs strip [Re: Hotchkis] #1081658
09/27/11 08:26 PM
09/27/11 08:26 PM
clarks summit pa
clarks summit pa
Would the strut rods have any noticeable affect on a car that's mainly street driven?
Re: Suspension mods for street vs strip [Re: 73cuda340] #1081659
09/29/11 03:31 PM
09/29/11 03:31 PM
Hotchkis Offline
Hotchkis  Offline
73Cuda340 - The heavy duty Hotchkis strut rods eliminate control arm deflection during hard braking and hard cornering so the geometry stays true for best driving performance. So if you will notice it depends on how you drive on the street.
