Suspension mods for street vs strip
#1081642
09/24/11 06:31 PM
09/24/11 06:31 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
I was looking at getting some of the hotchkis suspension parts for my cuda to replace the factory ones. Mainly, I was looking at the sway bars but if I was to put a set of their 1.03" torsion bars in, how much would this hurt the cars weight transfer and affect the cars ability to launch? This will be a street/ strip car so I'm kind of stuck between building the car to doth both. Thanks for any help.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Suspension mods for street vs strip
[Re: PHJ426]
#1081647
09/25/11 12:36 PM
09/25/11 12:36 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
.....unless you need a car that goes deep into the 10's or faster and also corners with the kids in the back seat eating ice cream with the dvd's playing for them with the a/c cranking.
Ice cream in the car is out of the question, but the availability of hydraulic roller cams, stroker kits, and great aftermarket heads give us the power. Caltracs with split monoleafs, great shocks, Firmfeel's swaybars, upper control arms and power steering box mods, US Cartool subframe connectors and modern tire technology(like 325/ 50 15 Nitto 555r's) that provides mind-boggling traction; give us control of the road AND the ability to launch. Don't forget to add Perfect fit Vintage Air A/C with a hidden compressor kit from Bouchillion, a few bulk packs of well placed Dynamat Extreme and cocoon up the rest of the interior with rolls of The Insultor Mat from AirCraft Spruce and some aluminum tape.
These days we can have our cake and eat it too, ala-mode if you like.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1081648
09/25/11 05:41 PM
09/25/11 05:41 PM
73cuda340
clarks summit pa
I'm not looking at building an autocross car. I would much rather have it be able to launch better than to take corners faster. I just was looking to improve on the handling a little but wasn't sure if it would be a big difference with the torsion bars added. Would this hurt alot of the cars ability to transfer weight or would it only be a small difference?
[Re: 73cuda340]
#1081653
09/26/11 11:05 AM
09/26/11 11:05 AM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
IMO, build it to be better mannered on the street than the strip. Will it imapcts its ability to transfer weight, yes. What will the impact be, maybe 2 or 3/10 of a second. We aren't talking huge differences here. Most street strip cars are far from having the ultimate drag strip suspension anyway, so giving up a couple more tenths for a safer street vehicle is no big deal. On top of that, you are likely running it as a bracket car. In this case, consistantcy is far more important the ultimate e.t. The firmer street suspension will be more consistent run after run compared to an all out drag set up.
[Re: TC@HP2]
#1081655
09/26/11 07:28 PM
09/26/11 07:28 PM
73cuda340
clarks summit pa
I'm not running it as a bracket car, just something that I can have fun with on the street and still put down some good times at the strip. The main reason Im so concerned about hurting the cars traction is because I have a 528 hemi in the car; so I can use every bit of help in the traction department.
[Re: 451Mopar]
#1081656
09/26/11 07:39 PM
09/26/11 07:39 PM
Pauls69
super gas
super gas
That 1.03" is a pretty stiff T-bar so the front won't rise much at all, but it should handle corners and dips well
i have the MP 1" bars on mine & would never go back. it rides & handles like a completely different car. the steering is still vague, but much of the understeer/plowing is gone. kinda wish i would have bought a larger bar now.
[Re: 73cuda340]
#1081657
09/27/11 01:12 PM
09/27/11 01:12 PM
Posts: 203 Sante Fe Springs, CA
Hotchkis
73Cuda340 – Having a Hemi in your Cuda is really sweet! Obviously however you decide to build the car is up to you, but as TC pointed out…building a car with better manners on the street makes for a car is so much more fun to drive. We get lots of coverage of our customer cars on the autocross track, but mostly because that’s a good way to demonstrate how well the cars handle. In reality, 90% of our customers don’t ever turn a wheel in anger, they simply want their car to have better road manners on the street. Our system improves overall feel and control without a punishing ride. So the next time you hop out of your modern daily driver and into your Mopar muscle car, you get modern handling with the power and sound we all love.
Here’s a double duty Challenger owned by a Hotchkis H-Team member:
[Re: Hotchkis]
#1081658
09/27/11 08:26 PM
09/27/11 08:26 PM
73cuda340
clarks summit pa
Would the strut rods have any noticeable affect on a car that's mainly street driven?
[Re: 73cuda340]
#1081659
09/29/11 03:31 PM
09/29/11 03:31 PM
Hotchkis
73Cuda340 - The heavy duty Hotchkis strut rods eliminate control arm deflection during hard braking and hard cornering so the geometry stays true for best driving performance. So if you will notice it depends on how you drive on the street.
