Cruise control ideas? #1081318
09/24/11 09:54 AM
09/24/11 09:54 AM
Midland, Tx
rjones Offline OP
rjones  Offline OP
Midland, Tx
Has anyone retrofitted a cruise control on a classic muscle car. If so how did you get it done?
Roger
Re: Cruise control ideas? [Re: rjones] #1081319
09/24/11 10:12 AM
09/24/11 10:12 AM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
Just-get a after-market kit from JCW and follow directions. Pretty simple operation.
Re: Cruise control ideas? [Re: dOOc] #1081320
09/24/11 12:13 PM
09/24/11 12:13 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Whitney did not have anything for older cars. Summit has this:
http://www.summitracing.com/parts/RPC-250-1223
Back in the day, everybody and their brother had kits for carburetor cars, Dana being the most popular. Today, not so much.
Craig
Re: Cruise control ideas? [Re: denfireguy] #1081321
09/24/11 12:21 PM
09/24/11 12:21 PM
minnarusta
TX9H6E4CUDA Offline
TX9H6E4CUDA  Offline
minnarusta
Im actually adding factory cruise to my superbee. If you get all the pieces it looks pretty straight forward.
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Cruise control ideas? [Re: TX9H6E4CUDA] #1081322
09/24/11 01:53 PM
09/24/11 01:53 PM
Dalton, MA
Slipknot440 Offline
Slipknot440  Offline
Dalton, MA
i've got a cruise unit from a cbody.. Just picked up a mopar lever and wiring harness off ebay a few months ago and have no idea where to begin with it
Re: Cruise control ideas? [Re: Slipknot440] #1081323
09/24/11 03:41 PM
09/24/11 03:41 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I installed Audiovox kit on my '84 D100, 225, 833od. It works great. This kit appears to be out of production.
To ease the instalation of the bracket to hold the servo throttle cable, I grabbed the OEM double cable clamp from a junkyard slant six with factory cruise. The clamp holds both the original foot pedal and the new servo cables. I think the S6 and V8 used the same double bracket.
The biggest hassle was mounting the magnets on the drive shaft and the bracket for the pick-up. There once was a GM Signal Generator that was used on early '80s Buicks that attached to the trans where the speedo cable went and the speedo cable then attached to the GM SG. This SG would make for a clean and simple installation but it is no longer in production.
EDIT: Here's a Audiovox kit like I used selling on Ebay.
EDIT: Here's the Echlin VSS232 replacement Buick SG that is discontinued. Find one and it will make the install easier.
Re: Cruise control ideas? [Re: B5 Bee] #1081324
09/24/11 04:17 PM
09/24/11 04:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There's a boatload of cruise kits on Ebay that work on the old style cars. They use a magnetic pick up on the drive shaft to trigger the system.
Re: Cruise control ideas? [Re: stumpy] #1081325
09/25/11 10:26 AM
09/25/11 10:26 AM
South Dakota
W
wireweld Offline
wireweld  Offline
W
South Dakota
What about the Dakota Digital cruise control kit? It uses a signal from the speedo.
Re: Cruise control ideas? [Re: wireweld] #1081326
09/25/11 11:08 AM
09/25/11 11:08 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I wish that kit was available when I did my D100. They have a adapter to use the GM signal/pulse generator on a Mopar with speedo cable. The pulse generator is the way to go, driveshaft magnets & pick-up are a pain to deal.
With the OEM double throttle clamp, that kit would be almost a bolt on operation.
Re: Cruise control ideas? [Re: stumpy] #1081327
09/25/11 11:16 AM
09/25/11 11:16 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I had a Heathkit digital speedo and cruise control that used the magnets on the drive shaft. The magnets stayed there about a year and flew off, never to be seen again.
The really efficient way of doing it would be to use a Vascar encoder. They attached to the rear of the speedometer in between the cable and the head. I think it used an optical shutter system to encode distance and from that, speed. It was very accurate. I have seen posts on here wondering what that was from police package cars.
Craig
Craig
Re: Cruise control ideas? [Re: Slipknot440] #1081328
09/25/11 01:24 PM
09/25/11 01:24 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
If you have a Factory Service Manual which shows the Speed Control wiring schematics, it's not too difficult to set up on any other similar era Mopar.
You can even grab most of the parts from a late '80s M-body if you don't want to mess with a trans sensor. Mount the servo in the engine compartment, run two speedo cables-- one from the trans to the servo, the second from the servo to the speedo head, and connect/run the wires. You'll need a different brake light switch with four wires, and if you're installing it on a manual trans vehicle, you'll probably want to add a clutch switch too, which the factory never offered.
I think using a factory setup is the easiest and cleanest looking installation method if you want to retain the factory look. The trick is finding a good, working servo.
Don't forget to add one of these when you're finished:
Re: Cruise control ideas? [Re: rjones] #1081329
09/26/11 08:13 PM
09/26/11 08:13 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Roger
What kind of car? It's very easy to add factory cruise control to most mopars in the '60s on up. There are some exceptions because some parts are tricky to find. The mopar cruise control from the era is very reliable and simple to use.
