Re: whats the difference betwwen a 10.95 and 11 inch clutch
[Re: 70RT383]
#1081306
09/24/11 11:49 PM
09/24/11 11:49 PM
Posts: 1,051 Slidell, La.
doctor_mopar
Slidell, La.
Apparently, You have the 143 tooth 11 inch pattern flywheel. Of course you must have the bellhousing that goes with it. This is a 69 and earlier cast iron set up. Like was said. You can use the 10.95 disc, but need the true 11 inch plate. What must have confused McCloud was the 70 year, but you have the incorrect 69 size.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: 70RT383]
#1081307
09/25/11 01:20 AM
09/25/11 01:20 AM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
concidering where you are located, It would probably be alot quicker and cheaper to have a good machine shop drill and tap your flywheel to accept the 10.95 pressure plate.
